Old 10-21-2009, 01:56 AM   #30
ellenbetty
ellenbetty
ellenbetty's Avatar
Drives: 2 2007 Yaris 3 door liftback
You forgot number 10. Your mother should have washed your mouth out with soap more often.
1. I installed the fog lamps to extend the life of the low beam filaments.
2. disconnecting the fog lamp kits had zero effect on the problem.
5. It is a waste of gasoline to drive a car at highway speeds for 2 hours just to charge the battery, unless one is being chased by zombies. Most of the energy generated by burning gasoline would be consumed moving the weight of the car and fighting aerodynamic resistance. Running the motor for 2 hours while parked to charge the battery would consume a lot less gasoline.
8. Most modern motors have a temperature sensor in the cylinder block to inform the car's computer what temperature the cylinder block is. If the cylinder block is cold the gasoline will be cold as well.
7. There is quite a bit of difference between the different types of magic, which can be broken down into stage magic, which is based upon the concept of misdirection and misinformation, story telling magic, which is based a child's inability to tell the difference between make believe and reality, and how a battery powered jump starter works.
Inside of the battery powered jump starter is a lead acid battery which works by using electricity, which is made by the movement of free electrons, electrons released by chemical reactions or electrons movement on the surface of metal wires, caused by the movement of conflicting magnetic fields. The one way movement of electrons is used to break the chemical bond between lead and sulfur to create sulfuric acid, a unstable chemical compound used to store electrical energy. The lead acid battery is formed by the arrangement of layers of thin lead plates, held in place by the battery casing. The thin lead plates are surrounded by water mixed with sulfuric acid. The water, combined with how the lead plates are attached to each other in a directional pattern, directs electrons to flow in one of two directions.
A battery powered jump starter is group of components attached to a lead acid battery. When the cables attached to each end of the lead acid battery are attached to another lead acid battery, a circuit is created, permitting the free flow of electrons. The sulfuric acid reacts with the lead plates to release a large number of free electrons which flow in one direction because of the layout of the lead plates in relation to the sulfuric acid. The directional flow of electrons are used to jump the electron flow through the vehicle motor to start the motor.
When the battery powered jump starter is attached to the terminals of a discharged lead acid battery for a prolonged time, the electric power stored in the battery inside of the jump starter will flow into the discharged battery, transferring part of the energy stored in the battery in the jump starter to the discharged automobile battery.
9. Did I miss explaining any thing of importance?
ellenbetty is offline   Reply With Quote
HELP!!! I went back to the service center yesterday for the 7th time in 2 months! Meldav86 General Yaris / Vitz Discussion 27 08-21-2007 09:04 PM
DIY - HID Retrofit Violin DIY / Maintenance / Service 57 06-11-2007 06:17 PM
Did you order fog lamps? Driver New YARIS Purchase Forum 27 11-29-2006 06:27 PM
Where to find Yellow capsules for fog lamps? W.A.S.P Cosmetic Modifications (Exterior/Interior) 0 11-26-2006 01:01 AM
