Old 10-12-2009, 02:11 AM   #1
eddy
love to drive
Drives: 2010 yaris sedan
Unhappy oil drain plug- gasket
does anyone know the size of the oil drain plug-gasket.
eddy is offline   Reply With Quote
Old 10-12-2009, 02:22 AM   #2
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
The plug is 14mm-1.5. A gasket with 8mm ID and 14mm OD should work.
Old 10-12-2009, 02:34 AM   #3
eddy
love to drive
Talking
thanks have not changed the oil yet and did not want to get stuck without the right one happy thankgivings
Old 10-12-2009, 07:33 AM   #4
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
I've never used one. I didn't even know it was there till a few months ago. But i havent leaked at all, so I dont worry about it.
Old 10-12-2009, 08:06 AM   #5
1stToyota
1stToyota's Avatar
Mine stays stuck to the pan and still looks good because I don't over-torque, so I leave it be.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 10-12-2009, 12:04 PM   #6
linny
Drives: '08 liftback mt
Last year I put the fumoto valve in. I have changed the oil twice since and all I have to do is put a pan under the car and push and slide the little lever. After the oil is drained out you just slide the lever back. It is really sweet!
linny is offline   Reply With Quote
Old 10-12-2009, 12:14 PM   #7
WolfWings
WolfWings's Avatar
Just swing by any toyota dealership. They sell bags of like... a thousand of those washers for a few bucks. At least the parts department at the local dealership is more than happy to hand those washers out like candy, just so you have the right part and since it's so cheap anyways.
Old 10-12-2009, 01:13 PM   #8
bronsin
bronsin's Avatar
That sealing washer is an amazing little gomer. The one on my ECHO is still there after nearly nine years and 27 oil changes and still seals perfectly.
Old 10-12-2009, 02:53 PM   #9
yaris-me
Learn to Relax
Fumoto!
Old 10-12-2009, 04:29 PM   #10
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
anybody got a link to this fumoto easy change plug adapter gadget (or a pic of it installed)? Depending on what it looks like, i'd be tempted to buy one. I fear what would happen if I ran over a piece of debris at highway speeds. A picture is worth a thousand words.... and possibly a sale.
Old 10-12-2009, 05:20 PM   #11
bronsin
bronsin's Avatar
Hmm so you just have to flip a lever to dump the oil out of the crankcase with the Fumoto?
Old 10-12-2009, 05:44 PM   #12
1stToyota
1stToyota's Avatar
Yes, and it almost sticks out like a sore thumb.
Jegs has the Fram Sure Drain for $24.00, cheaper at Amazon.
No lever. Attaching drain hose opens spring loaded valve. After oil drain, with hose off, you thread on o-ring sealed cap, so it's double sealed.
Fumoto
2008 Scion xD
Old 10-12-2009, 09:40 PM   #13
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
I've never changed the gasket on mine, it's stuck to the oil pan and has yet to leak at all.
Old 10-12-2009, 11:34 PM   #14
bronsin
bronsin's Avatar
What happens if it opens when youre driving? (nevermind I know what happens!) Hard to improve on a ten cent bolt. (and its free!)
Old 10-13-2009, 01:09 AM   #15
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
yea i never ever have changed the oil gasket. Never had a leak
http://www.4055design.com
Old 10-13-2009, 02:26 AM   #16
yaris-me
Learn to Relax
http://www.qwikvalve.com/home.php
I've used Fumoto on four cars so far and have never had a problem. You can place the valve lever on the top so it's away from the road. It's a lot better than the Fram and cost about $2 more. I tried the Fram on an old used car that I had and it is a POS.
Old 10-13-2009, 08:43 AM   #17
1stToyota
1stToyota's Avatar
That's only a concern with the Fumoto
The Fram has no lever, it has the internal pressure seal that only gets activated when you screw on the drain hose during an oil change, plus it also has the redundant outer seal and screw on cap, and it's a lot smaller.
Most Fram SD p/n's @ amazon are less than $8.00, over $20.00 less than the Fumoto @ amazon
I believe ours is the SD-3 [M12x1.25], not a M14x1.50 as previously mentioned.
2008 Scion xD
Old 10-13-2009, 10:13 AM   #18
bronsin
bronsin's Avatar
If I was going to do it Id use the FRAM one. That Fumoto looks like potential $$$$$ trouble to me! Gee I COULD eliminate my 14mm wrench from the tool kit though!
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Oil drain plug gasket question schleppy DIY / Maintenance / Service 7 04-17-2009 05:35 AM
