#19 |
I had stability control in my scion xb and the only time it ever was activated is when i was trying to get it to.. being that the yaris is such a small car with a short wheelbase i don't anticipate any problems with winter driving this year.
#20 |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
Hi,
I am actually scared to try the VSC to ground. I am reading a lot about toyota VSC and there is a risk of losing the zero calibration if the unit. If I try the euro pin 30 ground, what does the owners manual state about how and when can this VSC off switch be used ? while stopped ? in motion ? engine off or on ? and does it need to be zeroed after use ? I don't want to possibly mess up the VSC and have it spin me into a tree if I really need to use it, and it thinks I am 45 degrees from reality.... if techinfo.toyota.com has the manual I will go sign up...in fact I think I will sign up |
#21 | |
I have the VSC docs from techinfo. Here's some of the info on the switch VSC OFF switch - Pressing this switch turns off traction control and pressing and holding this switch turns off traction and VSC controls. A30-30 (CSW) - Body ground (VSC OFF switch input) VSC OFF switch held ON - Below 25 Ω VSC OFF switch OFF (Not pressed) - 10 kΩ or higher |
#22 |
does the 2010 liftback auto also have tach or just the manual tranny has one?
#23 | |
yeah. I subscribed. did it for my 4runner (back when you could download the WHOLE TIS in one go with a script...I miss those days) VSC OFF it is a momentary toggle, and not prewired unless you have a switch. TRAC OFF MODE press the vsc off switch briefly the trac off indicator will come on system is in trac off and vsc ON mode push the switch again to turn system back on VSC OFF Mode stop the vehicle completely and press the VSC OFF switch for more than 3 seconds the slip and VSC OFF indicators will come on The system is in TRAC OFF and VSC OFF mode ------------ automatic reactivation of TRAC and VSC turn engine off automatic TRAC on...if vehicle speed increases automatic TRAC and VSC activation they will not reactivate when speed increases EPS operation when operating the steering wheel a motor sound may be heard OK I am not scared to wire this thing up anymore now that I know what to expect as a driver, and all I want was the TRAC OFF anyway....so it looks like....i will test this next week (no time to mess around this week, I spent enough time already with CC and MPG calculations...only got the Yaris Monday noon....) location of anti-death robot in the pic Last edited by 127.0.0.1; 10-08-2009 at 01:27 PM. |
#24 |
#25 |
Carp !
The combination meter does not have the VSC off and TRAC off led's in vehicles without the VSC off switch. So I can wire the -VSC off- all day, but I will have no indication it is actually off, or the status of it, unless I hog my own LEDS into the Combo meter.... dang this project is on hold for a while. I don't want to go in there just yet. |
#26 | |
And, the indicators are driven by the combo meter receiving CAN bus messages about VSC and TRAC being off, so that makes it almost impossible to add the LEDs. |
#27 | |
yup. I will need to go deep ($$$) if I really want VSC/TRAC OFF. I will just find out how it goes in snow, and if I get stuck. I just won't clown around. the 4runner is for that anyway.... |
#28 |
![]() Drives: 2010 Yaris 3Dr LB Join Date: Oct 2009
Just a note as a former stability control engineer - vehicles with short wheelbases are more unstable in yaw. It doesn't take much lateral movement to cause a high body slip angle, and anything over about 15 degrees is difficult for anyone but those with lots of experience to recover from. Just my 2c...
#29 |
Only Happy When it Rains
I'm so glad I got a Yaris before all the electronic nannying. But no drl's for 2010? Lucky, oh so lucky.
Colin Chapman disciple |
#30 | |
Heck, I don't even have ABS! I do have the DRLs, but so far no bulb has blown out in 1.5yrs of driving with forced on headlights...
#31 | |
As for the electronic nannying, I wish you could turn it off (without pulling the fuse!), but it sure is nice to have in an emergency. |
#32 | |
![]() ![]() ![]() ![]() Drives: 09 3dr LB MT Join Date: Aug 2009
2009 3dr LB MT Meteorite Metalic. Car bought 8/7/09. Now over 89k miles of trouble free driving, other than user error!!
#33 | |
#34 | |||
#35 |
the electric nannying will save a 'non-drivers' butt. those are the majority of drivers
but those who -drive-, and have had a lot of experience driving and getting things out of whack in the high school parking lot at night, it may be a problem I like VSC because I have had my little LeCar R5 Turbo get out of sorts once or twice and I was fishtailing everywhere at 70 mph and came within a hair of flipping it. Sore arms amd ribs later (from my very rapid counter-steering) saved me, but only just. if the Yaris gets out of whack, I will attempt the same, but VSC should make it easier. the TRAC is something I do not want, it has already left me stuck once...on a steep dirt driveway where I needed some spin to get up. trac keep bogging me down. anyhow....cannot disable it. I guess I just have to deal. no worries i like the little Yaris, it is like taking a break from driving the 4runner every day. I can whip the Yaris around a but and there is no danger of tipping over like the 4runner might. |
#36 | |
On a related note, a car behind me on the highway entrance ramp this morning spun out (did a 180) when she overreacted to a driver who wouldn't let them onto the highway. Luckily she didn't hit anything and was just shaken up. Oh, and it was mostly dry with some wet patches from yesterday's rain. Most likely if she had ABS she would have been fine... |
| PINOUT info stereo | ozmdd | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 12-14-2009 07:52 AM |
| $1,600 Government Rebate on Fatt Batt Insulation or Solar Hot Water Systems Info. | *MAD DOG* | Australia | 1 | 03-27-2009 09:44 AM |
| AutoX Info | KS SOLO | Tracking, Racing, Auto-X Forum | 1 | 04-02-2007 04:45 PM |
| bi-xenon info | Adriaan | Cosmetic Modifications (Exterior/Interior) | 0 | 02-05-2007 06:21 PM |
| car info | uncleyaris | General Yaris / Vitz Discussion | 6 | 01-26-2007 05:13 PM |
