![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
Multiple cylinder misfire under boost
Several months ago at an autox event, while under boost the Yaris posted a CEL and went into limp mode in the middle of the race. The codes showed misfires on multiple cylinders. Fortunately, the CEL cleared and the car ran fine if I stayed out of boost.
When I pulled the spark plugs, they were all coated with a dry reddish deposit. Today I put in a fresh set and the car runs as well as it did right after the blower was installed. The SC typically puts out 7lbs of boost. I use Shell V-Power gas at 91 octane. What causes this type of deposit? The plugs are NGK BKR7EIX Iridium with a heat range of 7. The plugs have been in since December of last year. I'm also running a set of 1ZZ injectors. AFR stays at 14.7 under normal driving conditions and then goes to 11-12 under boost. ![]() ![]()
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jul 2007
fuel with additives
Maybe I'll try someone else's 91 octane for a year and keep checking the plugs.
isn't 14.7 a bit lean?
Learn to Relax
Drives: 2007, Meteorite, LB Join Date: Dec 2008
It looks slightly rich, which is because of the 11-12 AFR. The deposits probably cause the misfire and replacing the plugs is the best thing to do. Probably best to replace plugs on a regular basis.
Ten months on a boosted car is pretty long for plugs. I would check them more often.
What is the gap?
What? Replace Iridium plugs every year or sooner? If I'd known that owning a S/C was this expensive, I... just kidding.
Thanks for all the suggestions. It's running great with a new set of Iridiums. Not to save money, but I'm going to Harbor Freight to get one of those spark plug blasters. I've always wanted to see how well they work.
Mike, what kind of gas do you use. With enough data points we can show what brands of gasoline leave what kinds of deposits. I've been using Shell V-Power exclusively. I put in one can of octane booster every other month on race day.
#9 | |
Learn to Relax
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
Red to purple deposits on one side of the core nose are an indication of a fuel additive. While many of these deposits are non-conductive and do not contribute to lack of performance, some fuel additives contain octane boosters that leave conductive deposits on the core nose. Care should be taken to select fuel additives which are compatible with ignition systems and do not contain conductive materials such as octane boosters.
#11 | |
Learn to Relax
Race day? Did someone say race day?
#14 |
Interesting, I just Turbo'd my car, there is a post...
It is good to know as I am also runing NGK Heat range 7 but the spark plugs are for the 1krfe 3cyl.... As far as I know fuel aditives is a no no, the cr*p they put in there is unbelivable sometimes, here is South africae we are quite lucky we can choose 93, 95, and 102.6 octain fuel for race day.... Have a look at my post, I found some stuff maybe worth mentioning.
--------------------------------------------------- “Do or do not... there is no try.”
| yaris timing belt | phenoyz | General Yaris / Vitz Discussion | 16 | 02-24-2015 01:05 AM |
| misfire on no 1 cylinder | beemer dave | DIY / Maintenance / Service | 9 | 05-25-2009 08:13 PM |
| Supercharger Selection and Limiting Boost | Nexus1155 | Forced Induction Forum | 1 | 12-01-2008 03:51 PM |
| DIY Hood Cylinder | churp | Cosmetic Modifications (Exterior/Interior) | 46 | 06-25-2007 05:46 AM |
| Canada Only - Maybe a $1000 enviro rebate on Yaris> | MDF | New YARIS Purchase Forum | 45 | 05-01-2007 08:17 PM |
