![]() ![]() ![]() Drives: Silver 2007 3Dr - Gryph Join Date: Jul 2007
Cruise Control Transplant 2009->2007 LB
Okay... everything swapped over aside from needing to cut a hole for the stalk. This is a factory cruise-control stalk on a USDM Liftback Yaris, sticks out on the lower-right towards the center console.
Is there two different spiral cable models? I'm asking as my socket had three pins and I swapped the ground/stalk cable from the 2009 model as well but I didn't have the tools or patience to unbolt the steering wheel and verify that. Also, swapped the clutch bolt over, but no wire to plug that into. What pins on where do I need to route that switch to? And what's the connector part number, if it's available as a seperate part?
Take a look at this thread:
You need to run the wire from the ECM to the stalk connector and run the two from the clutch switch to the under hood fuse panel. http://www.yarisworld.com/forums/sho...ghlight=cruise |
Yeah, I guess what I was wondering was is there a part number for the connector the MT clutch switch uses, so I can keep things plug-together instead of wire-splicing?
Also, regarding the steering-wheel to ECM linkage, do I need to replace the actual 'spiral cable assy' (84306-22010) with another part? If so, what's that part number? I replaced the 'wire sub-assy, horn button' (45107-52010) with the Y-cable from the 2009 model that included the plug for the cruise-control stalk in addition to the 'clip on' ground wire to the horn/airbag module. The 'spiral cable' socket under the airbag has only 3 pins present, all of which match the three wires from the Y-cable I'm using now from the 2009 Yaris.
#4 | |
The clutch switch connector (A29) is part number: 90980-10906. The pins for it are: 82998-24380 |
Thanks very much!
They couldn't find/order 82998-24380, is there any chance that part number changed?
The connector and other pins were spot on, but the closest part number they could find/order (24360) is utterly wrong for the connector so they didn't charge me for those.
There's an alternate pin shown - Part number: 82998-12340
Thanks much, that part number worked!
| Tags |
| 2007 lb, 2009 lb, cruise control |
| Cruise control install 2009 Yaris 3 door | PeteZNY | DIY / Maintenance / Service | 125 | 03-31-2024 09:22 AM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
| Retro fit Cruise Control into a 2009 Yaris hatchback | 42ezra | Performance Modifications | 1 | 05-02-2009 11:04 PM |
