Old 11-17-2009, 10:55 PM   #1
WolfWings
WolfWings's Avatar
Cruise Control Transplant 2009->2007 LB
Okay... everything swapped over aside from needing to cut a hole for the stalk. This is a factory cruise-control stalk on a USDM Liftback Yaris, sticks out on the lower-right towards the center console.
Is there two different spiral cable models? I'm asking as my socket had three pins and I swapped the ground/stalk cable from the 2009 model as well but I didn't have the tools or patience to unbolt the steering wheel and verify that.
Also, swapped the clutch bolt over, but no wire to plug that into. What pins on where do I need to route that switch to? And what's the connector part number, if it's available as a seperate part?
Old 11-17-2009, 11:55 PM   #2
Take a look at this thread:
You need to run the wire from the ECM to the stalk connector and run the two from the clutch switch to the under hood fuse panel.
http://www.yarisworld.com/forums/sho...ghlight=cruise
Old 11-18-2009, 01:31 AM   #3
WolfWings
WolfWings's Avatar
Yeah, I guess what I was wondering was is there a part number for the connector the MT clutch switch uses, so I can keep things plug-together instead of wire-splicing?
Also, regarding the steering-wheel to ECM linkage, do I need to replace the actual 'spiral cable assy' (84306-22010) with another part? If so, what's that part number?
I replaced the 'wire sub-assy, horn button' (45107-52010) with the Y-cable from the 2009 model that included the plug for the cruise-control stalk in addition to the 'clip on' ground wire to the horn/airbag module. The 'spiral cable' socket under the airbag has only 3 pins present, all of which match the three wires from the Y-cable I'm using now from the 2009 Yaris.
Old 11-18-2009, 08:52 AM   #4
The spiral cable is the same for 06-09 cars, so you don't need to change it. The three wires are there (cruise, cruise ground, and horn), you just need to add the pins to connector D3 on the steering column. The pins are part number: 82998-12870
The clutch switch connector (A29) is part number: 90980-10906. The pins for it are: 82998-24380
Old 11-18-2009, 09:11 AM   #5
WolfWings
WolfWings's Avatar
Thanks very much!
Old 11-21-2009, 03:38 PM   #6
WolfWings
WolfWings's Avatar
They couldn't find/order 82998-24380, is there any chance that part number changed?
The connector and other pins were spot on, but the closest part number they could find/order (24360) is utterly wrong for the connector so they didn't charge me for those.
Old 11-21-2009, 05:47 PM   #7
There's an alternate pin shown - Part number: 82998-12340
Old 11-29-2009, 02:13 AM   #8
WolfWings
WolfWings's Avatar
Thanks much, that part number worked!
2007 lb, 2009 lb, cruise control
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 10:22 AM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 07:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 04:55 PM
Retro fit Cruise Control into a 2009 Yaris hatchback 42ezra Performance Modifications 1 05-03-2009 12:04 AM
