| View Poll Results: Would you buy one? | |||
| No |
5 | 5.10% |
| Yes (for $75) |
46 | 46.94% |
| Yes (but it would have to be less than $75) |
7 | 7.14% |
| Yes (but I still want it to also display the time) |
40 | 40.82% |
| Voters: 98. You may not vote on this poll | |||
#163 |
pink wheels are cool
yea I am really excited about this, i really cant wait for it to get done!
#164 |
Here's another teaser - Mounted in my 09 with the orange LCD:
YarGauge - Volts.jpg YarGauge - in.jpg |
#165 |
![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
How does the unit install to the car Scott? Does it read from the OBD2 port?
#166 | |
It communicates with the ECM via the CAN bus, but it grabs it at the cluster, so you can still have a scangauge or other device use the OBD port. |
#167 |
just too cool for words
#168 |
And what about clusters with the clock on the other side? Will compatibility be similar?
#169 |
I like that it will be able to maintain the stock, orange color.
I do have one question ... I noticed that in the last pics, the cluster brightnees is turned up to what seems to be to max but the modual seems a bit dimmer than the other displays. If you were to turn the brightness down a bit like at night, will the new modual still be as visible as the rest of the cluster? Will the new modual indeed be able to be dimmed along with the cluster? Last edited by RedRide; 01-10-2010 at 11:37 AM. |
#170 | |
Right now I am not using the dimmer feed, so the display would be the same brightness with headlights on or off. Now that it is in the car, that's one thing I'll experiment with to determine if dimming is needed (I have a feeling it won't, as the backlit LCD is not as bright as the speedometer). |
#171 |
I'm still trying to figure that out. The ones with the clock on the right, are either LBs with the cluster with the tach, or are sedans. In both of those cases the odometer and fuel gauge are part of that display, so I can't really replace it. For those, I am trying to figure out another mounting place that would still have the OEM integrated look.
#172 |
Is there still going to be a sedan version?
#173 | |
Since it is "not as bright...... Often in bright, anbient light, the stock gage cluster is hard to read. Is this also a prblem with the new modual? Perhaps abient light does not effect it as much? Is there an easy way to conect it to the dimmer feed? |
#174 |
![]() ![]() ![]() ![]() Drives: '07 Yaris HB Join Date: Apr 2006
Question: Can the temperature display read in celsius as well as farenheit?
#175 |
#176 | |
1) Integrated as a clock in a small unit 2) Integrated via a single DIM unit like a scanguage? Just an idea! Keep up the great work Scott. |
#177 |
![]() ![]() ![]() ![]() ![]() Drives: 2008 Toyota Yaris Liftback Join Date: Oct 2008
Wow, i can't wait to get this! applause to you CTScott for a brilliant idea and execution!
C-Lift ![]() -------------------------------------------------------------- Current Mods: MI Armrest; Full LED conversion (interior and exterior); RS spoiler; Tinted windows; Tanabe DF210 lowering springs; aftermarket door speakers; 12" RF P3 subwoofer with custom box wrapped in Neffy; seat covers; HID 8000K headlights; HID 3000K foglights; 13mm PG hub spacers; muffler delete with dual tip; eyelids; and.. A little red Domo mascot!
#178 |
![]() ![]() Drives: 2008 Yaris LB Join Date: Oct 2008
unit looks nice....i can't wait till it comes out. would we use the current push button on the cluster to change between functions?
#179 |
![]() Drives: Yaris 2008 Sedan Join Date: Jan 2010
I am interested in how you'd incorporate it into the sedan! I'll buy.
#180 |
Yes. It will use the same push button to change modes and set the clock. Programming for the one button user interface has been one of the most difficult aspects of this, but I wanted to avoid making people drill holes for extra switches.
| in dash clock as tach? | Cosmonaut | In Car Entertainment + Electronics (audio / video / alarm) | 10 | 07-12-2010 11:27 AM |
| digital tach, 52mm, preferably blue leds | severous01 | Cosmetic Modifications (Exterior/Interior) | 5 | 05-15-2009 10:58 AM |
| Digital Tach | nqd | Performance Modifications | 4 | 05-17-2007 12:04 PM |
