View Poll Results: Would you buy one?
No 5 5.10%
Yes (for $75) 46 46.94%
Yes (but it would have to be less than $75) 7 7.14%
Yes (but I still want it to also display the time) 40 40.82%
Voters: 98. You may not vote on this poll
Old 01-09-2010, 11:14 PM   #163
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
yea I am really excited about this, i really cant wait for it to get done!
http://www.4055design.com
Old 01-10-2010, 12:57 AM   #164
Here's another teaser - Mounted in my 09 with the orange LCD:
Old 01-10-2010, 01:05 AM   #165
advocate
Drives: car
How does the unit install to the car Scott? Does it read from the OBD2 port?
Old 01-10-2010, 01:18 AM   #166
Once the full production units are complete, I'll post the install pictures, but basically: You unplug the clock's connector, pop the clock module out, and pop the YarGauge in, in its place. I realized tonight that only 3 tap splices will be necessary, as I can have the clock's power connector plug right into the YarGauge. The three taps are for CAN communication (two taps on the right cluster connector) and one to the AC amplifier for the outside temperature (which is easily accessible by the gas pedal). It uses the same switch lever as the clock as well.
It communicates with the ECM via the CAN bus, but it grabs it at the cluster, so you can still have a scangauge or other device use the OBD port.
Old 01-10-2010, 02:08 AM   #167
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
just too cool for words
Check out my Build thread:
Old 01-10-2010, 02:24 AM   #168
advocate
Drives: car
And what about clusters with the clock on the other side? Will compatibility be similar?
Old 01-10-2010, 11:25 AM   #169
RedRide
RedRide's Avatar
I like that it will be able to maintain the stock, orange color.
I do have one question ...
I noticed that in the last pics, the cluster brightnees is turned up to what seems to be to max but the modual seems a bit dimmer than the other displays.
If you were to turn the brightness down a bit like at night, will the new modual still be as visible as the rest of the cluster?
Will the new modual indeed be able to be dimmed along with the cluster?
Old 01-10-2010, 12:22 PM   #170
Right now I am not using the dimmer feed, so the display would be the same brightness with headlights on or off. Now that it is in the car, that's one thing I'll experiment with to determine if dimming is needed (I have a feeling it won't, as the backlit LCD is not as bright as the speedometer).
Old 01-10-2010, 12:26 PM   #171
I'm still trying to figure that out. The ones with the clock on the right, are either LBs with the cluster with the tach, or are sedans. In both of those cases the odometer and fuel gauge are part of that display, so I can't really replace it. For those, I am trying to figure out another mounting place that would still have the OEM integrated look.
Old 01-10-2010, 12:40 PM   #172
YarisSedan
Drives: 08 Yaris Sedan
Is there still going to be a sedan version?
Old 01-10-2010, 12:46 PM   #173
RedRide
RedRide's Avatar
This brings up another concern.
Since it is "not as bright......
Often in bright, anbient light, the stock gage cluster is hard to read. Is this also a prblem with the new modual?
Perhaps abient light does not effect it as much?
Is there an easy way to conect it to the dimmer feed?
Old 01-10-2010, 01:48 PM   #174
devinlamothe
devinlamothe's Avatar
Drives: '07 Yaris HB
Question: Can the temperature display read in celsius as well as farenheit?
devinlamothe is offline   Reply With Quote
Old 01-10-2010, 01:54 PM   #175
Yes. A switch bank on the back allows configuration of options including metric vs. US standard.
Old 01-10-2010, 04:11 PM   #176
advocate
Drives: car
A possibility would be to sell two versions then?
1) Integrated as a clock in a small unit
2) Integrated via a single DIM unit like a scanguage?
Just an idea! Keep up the great work Scott.
Old 01-10-2010, 05:47 PM   #177
custom Lftback
custom Lftback's Avatar
Wow, i can't wait to get this! applause to you CTScott for a brilliant idea and execution!
C-Lift
Old 01-10-2010, 09:32 PM   #178
arunto
arunto's Avatar
Drives: 2008 Yaris LB
unit looks nice....i can't wait till it comes out. would we use the current push button on the cluster to change between functions?
arunto is offline   Reply With Quote
Old 01-10-2010, 10:12 PM   #179
joshpjost
Drives: Yaris 2008 Sedan
I am interested in how you'd incorporate it into the sedan! I'll buy.
joshpjost is offline   Reply With Quote
Old 01-10-2010, 10:22 PM   #180
Yes. It will use the same push button to change modes and set the clock. Programming for the one button user interface has been one of the most difficult aspects of this, but I wanted to avoid making people drill holes for extra switches.
in dash clock as tach? Cosmonaut In Car Entertainment + Electronics (audio / video / alarm) 10 07-12-2010 11:27 AM
digital tach, 52mm, preferably blue leds severous01 Cosmetic Modifications (Exterior/Interior) 5 05-15-2009 10:58 AM
Digital Tach nqd Performance Modifications 4 05-17-2007 12:04 PM
