Old 01-23-2010, 09:56 AM   #19
Kongo-Otto
Drives: '09 Yaris & '10 Auris
Tech data from the new 6 speed:
1.33 Dual VVT-i 1NR-FE
6 speed gear ratios
1st 3.538
2nd 1.913
3rd 1.310
4th 0.971
5th 0.818
6th 0.700
Reverse 3.333
Final 4.055
Old 01-23-2010, 06:56 PM   #20
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
id imagine it depends on the final drive you've got in the transmission. i thought wikipedia showed that the 6th gear in the c60 is lower than the 5th in the yaris
The C64 has the same 6th gear as the C150 5spd. Both .815, but the C64 has a 4.5 final as the C150 is only 3.5.
The C64 is used in the Lotus and I think the Corolla XRS. But all other gears are the same.
I remember driving a '03 Yaris RS (Puerto rico spec.) that has the C152 in it. Same gears as the C52 from the '00~ Celica GT. With a 1.904 2nd gear and the 4.058 final you could do a burnout starting in 2nd.
The C160 on the other hand has an even low 2nd gear and lower final. So I can only imagine how a hard launch would do from 2nd.
Edit: Oops, went on a little rant there. Yes the C60/160 does have a higher 6th to the Yaris 5th, but the final is so much lower on the C60/160 that the end result is still more revs at the same speed.
Old 01-24-2010, 01:29 PM   #21
stouffer
stouffer's Avatar
Drives: Yaris SR 1.33 - 3 Door
My Yaris 1.33 SR gear knob...
stouffer is offline   Reply With Quote
Old 01-24-2010, 02:02 PM   #22
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Originally Posted by Maitre_Te_Te View Post
Hello
Anybody have try to put a 6 speed transaxel on 1nz-fe?
I own the C160 6psd transmission mated with a 1NZFE turbo. The gears are close ratio and it keeps on reving much more than normal 5spd trans.
When launching with high throttle the 1st gear complete in almost 4sec and 2nd gear in almost 2sec. Infact during drag races I usually launch with 2nd gear since it's pretty low aswell.
The main reason I installed the C160 since the trans is capable of more bhp compared to the C54 (stock one) and because it has the Limted Slip Differential.
Why would you need a 6spd trans?
Parmas is offline   Reply With Quote
Old 01-24-2010, 02:34 PM   #23
well yes, the final drive is different so you'd have higher rpms on the highway....but i was talking about removing the gears from a c60 and puting them into a c54 housing (or whatever the code for the yaris tranny is) so you could keep your stock final drive and use the c60 gears...
would that work? c54 final drive w/ c60 gears in a c54 bell housing?
Old 01-24-2010, 08:16 PM   #24
Bluevitz-rs
Ya got me on that one
Old 03-01-2010, 07:10 AM   #25
Parmas
Parmas's Avatar
check this out for C160 discussion
http://www.clubxb.com/forums/f28/2zz...wap-14428.html
Old 03-01-2010, 10:05 AM   #26
Bluevitz-rs
I just remembered that I had previously looked up both input and output shafts between the 5 spd and 6spd and they are totally different. Also, the final drive gear is part of the output shaft.
Bad Speed Sensor? dmehak DIY / Maintenance / Service 33 01-05-2011 10:17 PM
Max Speed in Each Gear for 5 speed man. Yaris with no tach?? 09TRD General Yaris / Vitz Discussion 53 09-24-2010 05:18 AM
Cold Idle Speed Question... cpnnz DIY / Maintenance / Service 9 11-04-2009 06:31 PM
Have I mentioned how much I hate Speed sensors? staticorex General Yaris / Vitz Discussion 13 05-28-2009 05:04 PM
Six speed Snyprwlf47 Performance Modifications 16 11-24-2008 10:04 PM
