Old 01-29-2010, 08:04 AM   #19
Originally Posted by Lucas13 View Post
CTScott what type or relay you recommend for making the fogs DRL ?
If you look at the link I posted above, it shows the Narva 68062 relay. That or the real Toyota one (90987-02027 or 90987-02012) is fine. Besides the relay, you'll need the small red wire assembly pictured in that thread, which routes the fogs through the factory wiring (I believe that MicroImage sells both the relay and the wire assembly).
It is possible to make the change with the aftermarket fogs wired with their own relay, but since each kit is a bit different, I couldn't give you the specifics without tracing all of the wires for the kit. That's why I recommend converting to OEM fog wiring first.
Old 02-03-2010, 06:38 AM   #20
Lucas13
Drives: 07 Yaris LB
That sounds good to me, Thanks a lot CtScott!
Lucas13 is offline   Reply With Quote
my Projector Fog lights project ezhacker1 Cosmetic Modifications (Exterior/Interior) 3 01-10-2010 05:21 PM
Fog Lights Poll Reeves360 Cosmetic Modifications (Exterior/Interior) 14 12-27-2009 02:00 AM
Sedan Fog Lights, few questions!(where to get) ( make into HID Fog Lights!!!) Lafiro Cosmetic Modifications (Exterior/Interior) 2 06-12-2009 03:56 PM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
