Old 02-01-2010, 01:15 PM   #37
90tsi
90tsi's Avatar
Drives: 09 yaris
i dont wanna jump in on this late but if i read and caught up correctly didnt you say you had the engine dynoed? i can see the 132 to there and not at the wheels with the few mods you do have. without the drive train loss you numbers are gonna be a little higher... but correct me if i misread
90tsi is offline   Reply With Quote
Old 02-01-2010, 01:41 PM   #38
I think you are correct, he got 132.4 bhp (brake horsepower).
Even with a 15% drivetrain loss (super conservative), that's close to 113 whp. with bolt-ons AND tuning, this is certainly possible.
at a 10% loss, it's 119 whp, that is a more "interesting" result.
Old 02-01-2010, 02:00 PM   #39
slothman86
slothman86's Avatar
Drives: 07 Yaris Liftback
doing it right
Old 02-01-2010, 02:08 PM   #40
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
I concur that 132 at the crank doesn't seem all that hard-to-achieve. I'm pushing 110-115 at the wheels with strictly bolt-on stuff (intake, pulley, exhaust, wheels)
At the same time, this all sounds very haphazard and unscientific. I'd love to believe it, but you don't back it up with any pics or dyno sheets. When/how did you hook-up your engine to a dyno? Are you sure this isn't an "estimated HP" thing?
Also, aren't you getting any CEL's from your modified intake/throttle body?
Seriously, post a pic of this intake bypass for us to check-out.
Old 02-01-2010, 06:56 PM   #41
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
+2 More info on this "aux intake " set-up , thnx
Old 02-01-2010, 07:11 PM   #42
Master Shake
Drives: 2010 Red Yaris manual
I am a disbeliever.
Master Shake is offline   Reply With Quote
Old 02-01-2010, 08:58 PM   #43
sujonol78
Drives: 1nz-fe / MT
Send a message via Yahoo to sujonol78
no, forged rods are the same exact specifications as stock ones, in terms of shape and function. I have forged rods with stock camshafts and stock crankshaft.
Changing the rods simply does not change the power output of the motor.
i understand, but my idea of replacing the con-rod is with "lighter" con-rod material, if it is lighter, i think it will affect the lower power band. that's why when i change to the lighter rod, i will also change the camshafts. what do you think?
sujonol78 is offline   Reply With Quote
Old 02-01-2010, 09:02 PM   #44
sujonol78
Drives: 1nz-fe / MT
it seems that we have a misunderstanding about the dyno method. as i mentioned before, it was on engine. for the next step i will use on the wheel
Old 02-02-2010, 04:17 AM   #45
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
subscribed :)
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
Old 02-02-2010, 04:34 PM   #46
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Reducing conrod weight will have only a very marginal effect on the reciprocating mass. In other words, I severely doubt if you could tell the difference while driving it.
rob323 is offline   Reply With Quote
Old 02-02-2010, 05:43 PM   #47
+1
Old 02-02-2010, 10:18 PM   #48
sujonol78
Drives: 1nz-fe / MT
thanks for the info, i will keep it in mind for the next step.
Old 02-03-2010, 08:30 AM   #49
Jerkratt
Jerkratt's Avatar
ur drive by cable?
"It hurts more when its wet"
Old 02-08-2010, 05:03 AM   #50
sujonol78
Drives: 1nz-fe / MT
Originally Posted by Jerkratt View Post
ur drive by cable?
if i understood you correctly, the answer would be 'yes',
i'm not using the electronic throttle control
Old 02-08-2010, 01:34 PM   #51
ozmdd
ozmdd's Avatar
How did you connect the dyno to the engine?
Anybody in the Phoenix Area want to have a get together? kustom play Southwest 12 09-13-2009 11:52 PM
FS: Micro Image 1NZ Engine Cover (Black) Treyz Items for Sale by private party 10 06-13-2009 01:04 PM
1NZ port & polish ChinoCharles Performance Modifications 75 06-01-2009 06:39 PM
Ask The Phoenix The Phoenix Off-topic / Other Cars / Everything else Discussions 25 09-06-2007 09:24 PM
Tuned a DBW Toyota yesterday Turbo&Auto Performance Modifications 17 08-17-2007 12:04 AM
