Old 02-01-2010, 02:17 PM   #1
DerFlosser
DerFlosser's Avatar
Drives: Yaris
Question regarding replacing studs...
I am considering using a spacer in the rear and while searching, I was not able to come across an answer to my question. Is replacing the studs as easy as driving them out after taking off the face of the drum? OR...does one have to remove the pads, springs, pins etc....as well as the rear plate to drive out the studs and insert the new ones? I can't get my car on the lift as my other car is currently in the garage so...any insight would help.
DerFlosser is offline   Reply With Quote
Old 02-01-2010, 04:03 PM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
why not use these http://shop.microimageonline.com/Rea...cers-PGHS1.htm
They come in 10 or 12mm thickness
Old 02-01-2010, 04:07 PM   #3
DerFlosser
DerFlosser's Avatar
Drives: Yaris
I already have them.
Old 02-01-2010, 05:07 PM   #4
kngrsll
Apexing Egg!!
kngrsll's Avatar
yah, just knock them out with a hammer, get an open ended nut, and tighten them back in!
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 02-01-2010, 05:18 PM   #5
YAR1S
YAR1S's Avatar
its pretty easy once you get the drum face off.
and you can even use some m8(i think) bolts to get the drum off without tapping it with a hammer.... worked very well with mine.
-Jen <3
Old 02-01-2010, 07:44 PM   #6
DerFlosser
DerFlosser's Avatar
Drives: Yaris
I just looked at some pictures and it doesn't look like there is enough room to get the old studs out nevermind get the new ones in. Can somebody who has actually done this let me know if it's possible by only removing the drum face? Thanks again!
Old 02-01-2010, 08:31 PM   #7
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Never mind... thinking of hub bolts.
Old 02-02-2010, 12:29 PM   #8
DerFlosser
DerFlosser's Avatar
Drives: Yaris
OK....so in the 07' Repair Manual it seems to state pictorally that you can indeed knock them out after simply removing the drum face. For those that went with the 10mm spacers....how much longer is the stud? Is it a full 10mm or is it more like 5mm? I am assuming that the lenght is negligible upon installation of the new studs. I really would love to confirm this. Thanks!
Old 02-02-2010, 12:48 PM   #9
H&R studs are longer by exactly the width of the spacer. I can't answer for other brands.
Old 02-02-2010, 01:28 PM   #10
DerFlosser
DerFlosser's Avatar
Drives: Yaris
Thanks for that bit of input. I am also curious as to how those who have done this keep the hub from turning when pulling the new studs through(that is aside from the screwdriver trick in the repair manual).
Old 02-02-2010, 02:00 PM   #11
I pulled mine through with an electric impact wrench. Worked beautifully without spinning the hub.
Old 02-02-2010, 02:02 PM   #12
DerFlosser
DerFlosser's Avatar
Drives: Yaris
Great. Thanks! Did you upgrade to longer studs?
Old 02-02-2010, 02:10 PM   #13
Had to. Stock studs with a 10mm spacer only left me with approx 3 or 4 exposed threads for the wheel lugs to grip. Also explains why I responded about using an impact wrench to pull them through ;)
Old 02-02-2010, 02:17 PM   #14
DerFlosser
DerFlosser's Avatar
Drives: Yaris
Had to. Stock studs with a 10mm spacer only left me with approx 3 or 4 exposed threads for the wheel lugs to grip. Also explains why I used an impact wrench to pull them through ;)
OK....was this on the front or rear? The reason I ask is because I am trying to find out if I am on the right track here. If it was the rear, can you install these by simply removing the drum face and hammering out the old studs while simply installing the new ones through the back of the hub face (using said washer, lugnut and impact)? I am trying to prepare myself for a simple 30 minute to 1 hour job as opposed to thinking it's super simple and spending 6 hours on it and being frustrated as all hell. Your input if greatly valued!
Old 02-02-2010, 02:22 PM   #15
Question first. Are you installing hub spacers or wheel spacers?
Old 02-02-2010, 02:26 PM   #16
DerFlosser
DerFlosser's Avatar
Drives: Yaris
wheel spacers. I already have hub spacers. Hub spacers don't affect stud length as you know.
Old 02-02-2010, 02:35 PM   #17
Thought so, just wanted to be sure. Post#3 confused me a bit.
So yes, it is as simple as all that.
- pull of drum
- start a lug nut onto the stud to protect threads and tap out with a hammer
- insert new longer strud through back of mounting plate. There are only a couple of spots within the drum where there will be enough room to slid the new studs in.
- slid on washer and nut, and tighten down
Done.
Old 02-02-2010, 02:37 PM   #18
DerFlosser
DerFlosser's Avatar
Drives: Yaris
- pull of drum
Done.
Awesomeness. Thank you very much for confirming this!
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 09:44 AM
Voltage regulator and Amperage question... cr.chango DIY / Maintenance / Service 13 11-24-2009 12:59 PM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 03:57 AM
New Yaris + warranty Question hpvampiress New YARIS Purchase Forum 9 06-29-2009 06:39 PM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
