Old 03-01-2010, 01:01 PM   #541
NonStopTuning
Originally Posted by lammy29 View Post
thanks... i think i might order it off garm as i am interested in buyiny aFe intake and perhaps little cheaper for shipping..... btw does garm get his orders from you?
Yes, Garm (MicroImage) is the largest Authorized NST Retailer of products for the Toyota Yaris. He places orders with us frequently.
MIKE @ NST
www.NonStopTuning.com
Old 03-02-2010, 11:38 AM   #542
yarstar
Drives: 2008 Absolute Red HB
40K/2 years now on my Underdrive Pulley Set. Still Lovin' every take off! Really, really helps. Great, high quality upgrade. Thanks again, NST.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 03-05-2010, 12:16 AM   #543
NonStopTuning
MIKE @ NST
Old 03-18-2010, 05:02 AM   #544
Schizoprenia
Drives: Toyota Yaris 1.5 M/T '06
Hi NST,
i just want to enquire something. ur parts here in this side of the world isn't so common(Indonesia) i needed more information, if i have the Thai's built yaris, would i need a different set that is intended for the asian built ones? i know that waterpump doesn't fit right away but requires some sort of spacer if im not wrong, correct? can you please elaborate and maybe provide more information on the other crank underdrive as well as the alternator. thanks.
Schizoprenia is offline   Reply With Quote
Old 04-06-2010, 11:51 AM   #545
Yariz
Drives: Yaris 3dr Hatchback
can someone point me to the new DIY for this, I keep getting the one that has moved.
Yariz is offline   Reply With Quote
Old 04-06-2010, 07:23 PM   #546
NonStopTuning
Originally Posted by Schizoprenia View Post
Hi NST,
Thank you for your interest in our site and products, we appreciate it.
I have posted this info several times in this thread, but will post for you again...
IFFF your 1.3 or 1.5 Yaris has a single-row (one belt) crank pulley, then you can order pulleys from our Yaris page on our website.
IFFF your Yaris has a two-row (two belt) crank pulley, then you will need to order pulleys from our Scion xA/xB page on our website.
Yaris 1.8L pulleys are also listed on our website on the Yaris and Scion xD page.
Thanks again, good luck and have fun with all your projects!
MIKE @ NST
Old 04-09-2010, 09:45 AM   #547
Yariz
Thanks guys, I got it...
Old 04-14-2010, 11:10 PM   #548
NonStopTuning
No problem.
Good luck and have fun with all your projects!
MIKE @ NST
Old 05-13-2010, 11:09 PM   #549
Nets
Drives: yaris t-sport
I have a question, if the crank pulley has the same diameter as the one that comes origin OEM, whats the thing about changing the belt in the case of the ones that do not have AC? it does not make any sense
Nets is offline   Reply With Quote
Old 05-18-2010, 08:32 PM   #550
Astroman
Modded Moderator
Astroman's Avatar
I agree. If the belt is still in good condition you can keep using the same belt. I have AC and used my belt for another 60+ thousand miles after my crank pulley install. I just replaced it last week because it was finally starting to crack and wear after 80k miles. It was the original belt that came on the car.
Old 05-18-2010, 08:42 PM   #551
Comments about changing the belt are specific to the installation of the 10% UD pulley, not the CR Lite. In cars without A/C there is not enough swing on the alt bracket to achieve proper belt tension with the 10% UDP installed. Therefor a smaller belt is required.
Old 05-19-2010, 12:34 PM   #552
Nets
but my car has te same crank pulley as scion xA xB and it does not have AC so the diameter being the same it does not make any sence to change the belt
Old 05-20-2010, 12:45 PM   #553
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
Sent email, don't feel like sifting through 31 pages to find the answers to my questions.
The Spectacle is offline   Reply With Quote
Old 06-19-2010, 08:32 AM   #554
d1nzfe
Drives: 1NZ-FE
Great product, lasted me 50000km of use.
d1nzfe is offline   Reply With Quote
Old 06-19-2010, 07:48 PM   #555
*MAD DOG*
*MAD DOG*'s Avatar
Question
Did you install it yourself or get a mechanic to put it on?
Old 06-20-2010, 04:03 AM   #556
sito
Drives: Toyota
Bro d1nzfe, any damage to your engine?
sito is offline   Reply With Quote
Old 06-20-2010, 05:49 AM   #557
d1nzfe
Drives: 1NZ-FE
Of cos i got mechanic to do it. Damaged to my pocket.
Old 06-20-2010, 12:30 PM   #558
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
geez... i have the crank lite pulley, the w/p and alt were going to be my next purchase. maybe not....
goliath1812 is offline   Reply With Quote
