#541 |
![]() Drives: Toyota Yaris 1.5 M/T '06 Join Date: Oct 2009
Hi NST,
i just want to enquire something. ur parts here in this side of the world isn't so common(Indonesia) i needed more information, if i have the Thai's built yaris, would i need a different set that is intended for the asian built ones? i know that waterpump doesn't fit right away but requires some sort of spacer if im not wrong, correct? can you please elaborate and maybe provide more information on the other crank underdrive as well as the alternator. thanks. |
#542 |
Drives: Yaris 3dr Hatchback Join Date: Mar 2010
can someone point me to the new DIY for this, I keep getting the one that has moved.
#543 | |
![]() ![]() ![]() ![]() ![]() Drives: NST CARS: S13 AE86 ANT10 AW11 Join Date: Dec 2006
I have posted this info several times in this thread, but will post for you again... IFFF your 1.3 or 1.5 Yaris has a single-row (one belt) crank pulley, then you can order pulleys from our Yaris page on our website. IFFF your Yaris has a two-row (two belt) crank pulley, then you will need to order pulleys from our Scion xA/xB page on our website. Yaris 1.8L pulleys are also listed on our website on the Yaris and Scion xD page. Thanks again, good luck and have fun with all your projects! |
#544 |
Thanks guys, I got it...
#545 |
No problem.
Good luck and have fun with all your projects! |
#546 |
I have a question, if the crank pulley has the same diameter as the one that comes origin OEM, whats the thing about changing the belt in the case of the ones that do not have AC? it does not make any sense
#547 |
Modded Moderator
I agree. If the belt is still in good condition you can keep using the same belt. I have AC and used my belt for another 60+ thousand miles after my crank pulley install. I just replaced it last week because it was finally starting to crack and wear after 80k miles. It was the original belt that came on the car.
#548 |
Comments about changing the belt are specific to the installation of the 10% UD pulley, not the CR Lite. In cars without A/C there is not enough swing on the alt bracket to achieve proper belt tension with the 10% UDP installed. Therefor a smaller belt is required.
#549 |
but my car has te same crank pulley as scion xA xB and it does not have AC so the diameter being the same it does not make any sence to change the belt
#550 |
Sent email, don't feel like sifting through 31 pages to find the answers to my questions.
#551 |
![]() ![]() Drives: 1NZ-FE Join Date: Oct 2008
Great product, lasted me 50000km of use.
#552 |
Did you install it yourself or get a mechanic to put it on?
![]() "Manual labour is not for me. In fact i'm not even sure non manual work is either." -Anthony Linton Check out ▬▬► I like I like ◄▬▬ for more fun on Facebook |
#553 |
![]() ![]() Drives: Toyota Join Date: Mar 2010
Bro d1nzfe, any damage to your engine?
#554 |
Of cos i got mechanic to do it. Damaged to my pocket.
#555 |
![]() ![]() ![]() Drives: 2010 Prius, 2007 Yaris Sedan Join Date: Oct 2009
geez... i have the crank lite pulley, the w/p and alt were going to be my next purchase. maybe not....
#556 |
For the record, I had never seen something like this happen to an NST pulley before. You should let Mike know about this.
WP and ALT pulleys are much smaller and sturdier. I'd be willing to bet they're impossible to break.
#557 | |
But bro, the pulley shown is a water pump pulley, if i'm not wrong.
#558 |
