Old 03-03-2010, 06:28 AM   #1
jenfre
jenfre's Avatar
Drives: Yaris RS 2009 5DR
G-Tech RPM Issue ?
Hi, just got a used g-tech pro ss for 60 buck. I felt it was a good deal until i tried to set up the rpm sensor. I gave it few tries with no result. I searched on the forum about the g-tech and realized the yaris had a weak rpm signal. Can i do something more than turning on A/C, Fan, Fog Headlight etc to get it work proprely ??
Thankyou !!!
jenfre is offline   Reply With Quote
Old 03-03-2010, 11:45 AM   #2
06silveryaris
Drives: 2006 yaris
I gave up on setting RPM on mine but it works great measuting g s. I have also teste hp runs and always get around 100-103 hp. Which seems on mark
06silveryaris is offline   Reply With Quote
Old 03-03-2010, 12:38 PM   #3
Which "method" are you using to feed it the RPM signal? The Yaris actually has a very good RPM signal, if you use the TACH wire on the OBDII connector. If you are using the method where the GTech looks for ignition noise on the power wire, that would explain it having trouble, as modern cars have good ignition noise isolation.
Old 03-03-2010, 03:10 PM   #4
jenfre
jenfre's Avatar
Well I did know you could use the g-tech without configuring the rpm sensor. Ihave only plugged the g-tech in the 12V output.
Is there a way to connect the g-tech to that signal wire ?
Old 03-03-2010, 03:24 PM   #5
It looks like it depends on the model. The Gtech Pro EGS has a green wire for tach input. The SS and RS look like they can only read tach from the noise on the power input wire.
Old 03-03-2010, 05:09 PM   #6
jenfre
jenfre's Avatar
I have the SS... Tried another time this afternoon and it still did not work even with all electrical componement turned on. I think i will use it without rpm. Will it affect the g-tech data ? For the momment the g-tech tells 124 HP but i know i must have entered a to heavy weight. Anybodyknows the weight of a 5DR 09 Yaris ? Because i think the weight on the door panel is the max capacity of the car ? Correct me if i'am wrong
Turbocharged Dyno Result cdydjded Forced Induction Forum 24 08-23-2010 10:54 PM
yaris and yaris S Y@R15 General Yaris / Vitz Discussion 54 09-14-2009 12:40 PM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 12:41 AM
CONSUMER REPORTS : MARCH issue reviews '09 YARIS . gid General Yaris / Vitz Discussion 93 01-06-2009 04:10 AM
