Old 03-16-2010, 09:49 PM   #55
33OH
Drives: '08 Yaris
Hub spacer install - 1
Me - 0
Spent around 3 hours trying to get the hub assembly "un-stuck." Ended up calling it a night and putting it all back together.
Will have to pick up my air chisel I lent out and try again..
Old 03-16-2010, 09:52 PM   #56
33OH
Drives: '08 Yaris
Oh and FYI - the bolt size is a 12mm to get the drum off, you can use two that hold your hood on. (Use one from each side, obviously, so your hood can still stay on the car.)
Old 03-16-2010, 09:53 PM   #57
YAR1S
YAR1S's Avatar
how could you not get the hubs unstuck with the bolts? Im confused.... this did it for me....
-Jen <3
Old 03-17-2010, 07:48 AM   #58
33OH
Drives: '08 Yaris
It is seized onto the assembly. I'll have to grab an air chisel and see if the vibrations will knock it off.
Old 03-17-2010, 08:44 AM   #59
Tamago
Tamago's Avatar
Drives: UZJ100
don't use an air chisel.
rent a slide hammer kit
Old 03-17-2010, 12:26 PM   #60
33OH
Drives: '08 Yaris
Ah alright. Auto parts store I'm assuming will have one?
Old 03-17-2010, 12:32 PM   #61
Tamago
Tamago's Avatar
Drives: UZJ100
yeah, autozone for sure.
you could also re-install the wheel and kick against it from under the car, using it as leverage. i had a hell of a time getting the hubs off my MR2 to install my spacers too.
Old 03-17-2010, 12:38 PM   #62
33OH
Drives: '08 Yaris
Ah that's a good idea too with the wheel. I'll stop by autozone on my way home today. Thanks Joel.
Old 03-17-2010, 12:43 PM   #63
Is the e-brake released? Just checking ;)
Old 03-17-2010, 12:44 PM   #64
33OH
Drives: '08 Yaris
Yeah the e-brake was released. =)
Old 03-19-2010, 07:54 AM   #65
33OH
Drives: '08 Yaris
Btw - I got it. They look great!
Mounting the wheel onto the hub assembly was what did it for me. Had trouble getting the wheel OFF the assembly though, but a "chisel" and a sledge hammer did the job.
Old 04-29-2010, 02:02 PM   #66
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
... Shame on me, I just couldn't get the drum out )o: I'll try with the bolts that hold the hood.
D.
CLA 250, 4MATIC
Old 05-01-2010, 01:34 AM   #67
derickveliz2
Piece of Cake!
Now the 14 mm are giving me a hard time, I guess I need beefier tools... Or work out harder at the Gym!
D.
CLA 250, 4MATIC
Old 05-01-2010, 01:52 AM   #68
SUPER CLEVER
Old 05-03-2010, 09:24 AM   #69
derickveliz2
I did it! I did it! But only one side! The good thing is I'm going to be able to take photos of each side and compare! In real life It looks so GOOD! and this is only 10mm but makes such a big difference.
The right tools made a big difference, day and night, I'm a novice with real tools and mechanics, for me a guy who spends 60 or more hours per week in front of a computer, this is a big achievement!
I had trouble getting the spacer to fit, there was some "RUST" that made the inner circle impossible to fit with my hands, and the break like was so tight that I had to unscrew some points down the line to give me a little play and get everything back in place with the spacer in the middle. Used a lot of WD-40 and used the power of the tools to force/make the spacer fit.
We'll see how the other side goes tonight!
Thanks.
D.
CLA 250, 4MATIC
Old 05-03-2010, 01:01 PM   #70
derickveliz2
Here are the pictures...
From the Back:
From the Front:
CLA 250, 4MATIC
Old 05-03-2010, 06:01 PM   #71
awesome!!
Old 05-05-2010, 01:20 AM   #72
derickveliz2
Did the other side, it was much faster but at the end the RUST made everything a little challenging! but now every thing is OK.
Thanks "Pinguino" Spanish version!
D.
CLA 250, 4MATIC
Penguin Garage Rear Hub Spacers!! Penguin Garage Sponsors Classifieds Area 92 09-02-2009 06:16 PM
Gauging interest on hub spacers for the yaris Tamago Wheels, Tires and Suspension Forum sponsored by The Tire Rack 61 05-22-2009 02:18 PM
Rear Spacers... (Who sells them?) Saggio General Yaris / Vitz Discussion 6 02-06-2009 08:40 AM
Installing a rear window defroster trn9 DIY / Maintenance / Service 0 01-06-2009 02:56 AM
