Old 06-30-2009, 01:21 PM   #19
Originally Posted by Geology View Post
No hidden tricks?
No. I installed an aftermarket 07-08 kit on my 09.
I purchased the 09 OEM fog light trim pieces from my local dealer and the OEM fuse panel relay from an Ebay vendor. By purchasing the relay I was able to wire it using the factory wires that go from the under hood fuse panel, through the under dash fuse panel, to the headlight stalk connector (this is the same for 07-09). I didn't like the quality of the switch that came with my kit and didn't want to spend the money for a headlight stalk with the fog switch, so I used a different toggle switch.
Old 06-30-2009, 02:31 PM   #20
Treyz
~ ambient one ~
Treyz's Avatar
Originally Posted by regal View Post
If you order those part numbers from Sparks ...
Why do you guys always swear by Sparks ... I get parts cheaper at PartzNet.com (Conicelli Toyota), lol. People alwyas forget about them.
But to answer the Q of cheaper than $18 .. no I havent found them cheaper.
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 06-30-2009, 03:53 PM   #21
One thing that I forgot to mention, is that my 09 came with the FOG fuse already installed. I purchased a variety pack of the microfuses, and then when I got under the dash to install the fuse, I realized that the FOG spot was already populated.
Old 06-30-2009, 04:25 PM   #22
IsLNdbOi
IsLNdbOi's Avatar
Didn't know we had to install a fuse to get the fogs working. In my '07 all I did was connect the fogs to the box in the engine bay, plug the relay in inside below and to the left of the steering wheel and then install the new stalk.
Old 06-30-2009, 06:53 PM   #23
In that case, it sounds like that fuse is already there regardless of the year.
Old 07-07-2009, 12:31 PM   #24
PatrickJohnson
Drives: 2008 Yaris LB
do you happen to have part numbers on the oem trim and a specific seller on ebay for the relay? I think this will be my next mod.
PatrickJohnson is offline   Reply With Quote
Old 07-07-2009, 01:17 PM   #25
OEM trim pieces are Right: 81481-52330 and Left: 81482-52260.
I bought my relay from this ebay seller:
http://cgi.ebay.com/ebaymotors/Toyot...lenotsupported
Old 04-06-2010, 07:52 AM   #26
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Sorry to post here but does any one have photos of the Fog Light Combo
Stalk , Before and after it was instaled , Please
Old 04-20-2010, 03:28 PM   #27
Mouse
Drives: 2007 MX5
If I wanted to order just the Driver-side shroud....Would it be the RH or LH?
Mouse is offline   Reply With Quote
Old 04-20-2010, 04:50 PM   #28
Billiam
Drives: '10 White Yaris 4D LB
Driver = left side
Old 04-20-2010, 05:27 PM   #29
Mouse
Drives: 2007 MX5
I know it = leftside but if you look at the diagram at TRD Sparks it shows the driver side listed with the RH.
Old 04-21-2010, 04:43 PM   #30
Billiam
I'm getting ready to do a fog install myself...so I have the pieces you're talking about in my hand as we speak (well, type)....assuming you're talking about the surrounds for the '09+ LB.
Left side = #81482-52260
Right side = #81481-52330
Left side is certainly the driver's side and the right one is certaintly the passenger side. I verified this by holding it up to the car.
Sparks' info must be wrong.
Old 04-21-2010, 06:31 PM   #31
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
I have a set of 09-10 Hatch fogs and shrouds
100% plug and play and 100% complete $99.00US shipped
i also have 1 set for the 06-08 Hatch and 1 set for the Sedan
PM or email me for photo's .
Old 04-21-2010, 10:59 PM   #32
Mouse
Drives: 2007 MX5
Thank you all for your help. I only want the drivers side shroud to allow air into the fender area for my intake....Yes, it is for an '09 LB
Fog lights and shift knobs flip_yaris Cosmetic Modifications (Exterior/Interior) 4 09-26-2006 10:48 AM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
Fog lights for S sedans (US version) paeko73 General Yaris / Vitz Discussion 11 07-02-2006 11:38 PM
