Old 05-18-2009, 06:25 PM   #1
rihdrkc
Blazing Blue Yaris
rihdrkc's Avatar
Drives: 2009 Yaris 3 door Liftback
fog lights
Are there any fog light kits available for a 2009 3dr liftback? Will the ones for 07-08 fit?
rihdrkc is offline   Reply With Quote
Old 05-18-2009, 06:37 PM   #2
MGargano
Drives: 2009 Yaris Hatchback
Yes, the 06-08's fit but you need to get the shrouds for the 09. TRDSparks has them: RH- 8148152330 & LH- 8148252260. I used the Micro Image 06-08 LB fogs with these shrouds and the fit is perfect.
MGargano is offline   Reply With Quote
Old 05-18-2009, 08:44 PM   #3
rihdrkc
Blazing Blue Yaris
rihdrkc's Avatar
Thank you for the info
Old 05-19-2009, 08:55 AM   #4
DerFlosser
DerFlosser's Avatar
If you search...there is a host of information.
DerFlosser is offline   Reply With Quote
Old 06-01-2009, 01:14 PM   #5
regal
these are the wrong part numbers don't waste your money
Old 06-01-2009, 02:07 PM   #6
Actually, the part numbers above are correct. Here is a picture of mine, when they were still in the package with the part numbers:
Old 06-01-2009, 02:30 PM   #7
IsLNdbOi
IsLNdbOi's Avatar
I'm guessing no one sells a kit yet that comes w/ everything for the '09?...
Old 06-01-2009, 02:34 PM   #8
Not yet, and the Toyota plastic parts are highway robbery at $28 each from the dealer. I was highly tempted to just drill out the OEM trim pieces.
Old 06-01-2009, 06:20 PM   #9
1NZYaris1
1NZYaris1's Avatar
Are you sure the 07-08 sedan shroud's won't fit , in the 09 hatch back .
The look exactly the same just different part number's
Old 06-01-2009, 06:23 PM   #10
No. They are close, but definitely a different shape.
Old 06-02-2009, 01:41 AM   #11
regal
If you order those part numbers from Sparks you will get covers without holes for the lamps just like the ones you took off the Original. Just trying to avoid the problems I am going thu.
Old 06-02-2009, 08:20 AM   #12
MGargano
Then you received the wrong parts. The part #'s for the 09 covers without holes are RH- 81481-52110 & LH 81482-52100
Old 06-02-2009, 08:46 AM   #13
The dealership that I ordered mine through took two tries. I gave them the correct part number, but the parts guy looked it up himself in the EPC and ordered the hole-less ones. The second time around they used the part number that I gave them and got the correct ones.
Old 06-02-2009, 06:22 PM   #14
spookz
JDM yO!
Drives: '09 3dr. 5-spd
The part numbers are correct. I ordered with those numbers and I received the correct parts..
Those part numbers show up as the following on their systems:
81481-52330 - COVER, FOG LAMP, RH - FRONT FOG & DRIVING LAMP-WITH
81482-52260 - COVER, FOG LAMP, LH - FRONT FOG & DRIVING LAMP-WITH
The 09 shrouds without fog holes are 81481-52320 (RH) and 81482-52250 (LH).
Old 06-30-2009, 09:39 AM   #15
Geology
Drives: 2009 5 Door Carmine Red
How about installing the fog lights in the '09? pretty much the same as the lesser years?
The Geologist is a-rockin' and a rollin'!
Geology is offline   Reply With Quote
Old 06-30-2009, 10:14 AM   #16
Yes.
Old 06-30-2009, 11:32 AM   #17
Treyz
~ ambient one ~
Treyz's Avatar
I gotta order mine today when I pick up the car. I took out the Toyota OEM lamps that I bought for my'07 because I didn't want to order them again.
I left the Ebay ones on the car instead. Funny thing is though that I had 2 sets and both had one crack. They cracked on the same side so I took the other one and installed it upside down. It's a little off, but did the trick.
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 06-30-2009, 01:06 PM   #18
Geology
Yes.
No hidden tricks?
Is there any other place to get these covers that are cheaper than 18 bucks each?
Fog lights and shift knobs flip_yaris Cosmetic Modifications (Exterior/Interior) 4 09-26-2006 10:48 AM
can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. fantabulousbaby Cosmetic Modifications (Exterior/Interior) 22 08-29-2006 01:13 PM
Fog lights for S sedans (US version) paeko73 General Yaris / Vitz Discussion 11 07-02-2006 11:38 PM
