#37 |
#38 |
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
I'm confused again, since I'm getting 13.5-14.2v, according to the Scan Gauge. Is this too low? Or is it the fluctuation regardless of load that's the problem?
#39 |
As long as it isn't sagging below that then you are probably OK, but the alternator and regulator should be able to maintain a steady 14.1 at idle.
#40 | |
I guess I'll just swap the alternator and see what things look like with the "new" one. |
#41 |
I swapped the whole thing today with an '09 alternator with around 1,000 miles on it ($70). No change in voltage; it continues to fluctuate regardless of load and at idle.
When moving at a decent speed, it generally holds at 14.1v, but at idle and slower speeds, it fluctuates from 13.5-14.1. |
#42 |
Well after no change in voltage with the new alternator, I decided to do the "Big 3" upgrade.
I ran 1/0 wire from the alternator to battery +, and chassis/engine to battery - Zero improvement. Everything is exactly the same- voltage still drops to, and fluctuates around, 13.5 at idle/slow speeds and holds steady at 14.1 as long as I'm moving at a decent speed, all regardless of load. Hooray for wasting time and money. |
| NST NonStopTuning Pulley Kits | NonStopTuning | NonStopTuning | 19 | 11-08-2014 10:23 PM |
| FS: Blue Pulley Set | Shijima | Items for Sale by private party | 12 | 09-18-2009 08:34 PM |
| NST (NonStopTuning) Ebay Feedback & Rating | NonStopTuning | NonStopTuning | 0 | 07-19-2009 10:11 PM |
| Feeler: NST 10% Underdrive Crank Pulley - Gray | Black Yaris | Items for Sale by private party | 10 | 04-29-2009 11:24 AM |
| NEW GROUP BUY: NST WP-Lite & ALT-Lite Pulley Kit (NonStopTuning) | NonStopTuning | NonStopTuning | 266 | 09-29-2007 02:51 AM |
