Old 04-07-2010, 11:58 PM   #1
MGargano
Drives: 2009 Yaris Hatchback
NST Pulley Set Alternator Issue
I picked up and installed a full set of NST pulleys a little over a year ago. To my knowledge, they were not underdrive or overdrive pulleys, just the lightened version, but apparently (thanks to CTScott's diagnosis) my alternator is under-charging the battery.
I'm not sure if this is a new issue or if it has been doing this for the past year- either way, I'm curious why/how the non-underdrive pulley set could be causing this.
When running, the ScanGauge puts my voltage at 14.1 maximum, without any kind of load (amplifiers, head unit, etc.). Even 14.1 is rare- it's usually around low- to mid-13's.
I did a search and saw some people having the same problem with the 10% underdrive pulley, but I'm curious if anyone has run into this with the standard lightened set and what a potential fix might be. Something as simple as tightening the belt? Or something more drastic?
MGargano is offline   Reply With Quote
Old 04-08-2010, 12:06 AM   #2
1NZYaris1
1NZYaris1's Avatar
Simple solution , put the OEM pullie back on and retest , i bet you will
finf it is the Alternator that is Fualty ,and it will have nothing to with the Pullies .
It might also pay to check all connections betwen the alternator and the battery .
Aswell as the battery main fuse.
Old 04-08-2010, 12:20 AM   #3
MGargano
Should I replace all three pulleys with OEM? Or just the crank pulley?
Old 04-08-2010, 12:22 AM   #4
1NZYaris1
1NZYaris1's Avatar
Just The Crank
Old 04-08-2010, 03:17 AM   #5
shinlee
shinlee's Avatar
Drives: 07 liftback
I've got all 3 pullies on for over 2 years, never, not once, have I had a problem with my alternator, and thats with 3 subs in the car too.
Alternator is going out, no biggie, but it's not the pullies fault
shinlee is offline   Reply With Quote
Old 04-08-2010, 08:25 AM   #6
MGargano
I wasn't really blaming the pulley for doing anything wrong- I'm more curious to know if I received the correct one and/or if it was installed correctly by the shop I took it to.
For instance, if I received a 10% underdrive pulley by mistake, that would explain the lower voltage I'm seeing. Would a loose belt do the same thing?
Old 04-08-2010, 10:21 AM   #7
goliath1812
goliath1812's Avatar
Drives: 2010 Prius, 2007 Yaris Sedan
Even with the 10% underdrive pulley set, I thought there were still supposed to be no issues with under-charging...?
goliath1812 is offline   Reply With Quote
Old 04-08-2010, 10:51 AM   #8
MGargano
That's what I thought too, but I'm hoping for some confirmation so I can rule out the pulleys as the problem. I don't want to go through the hassle of putting the OEM pulley back on if it turns out to be a bad alternator.
I'm guessing a max of 14.2v while moving at speed with no load is considered "low"?
Old 04-08-2010, 11:44 AM   #9
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Just size up your stock pulley to your NST one if the one on your car is smaller than stock you have the under drive one.
Old 04-08-2010, 06:55 PM   #10
MGargano
Just checked- the two pulleys are identical in diameter, so I guess I have the right one installed, not the underdrive.
I guess that leaves the alternator as the culprit?
Old 04-08-2010, 09:11 PM   #11
What's the voltage @ 2500-3000 rpm? and how many miles/km on it?
Old 04-08-2010, 09:18 PM   #12
MGargano
Mileage is 10,906.
Voltage with no load at 3,000rpm is 14.1v- but it definitely does not hold that voltage while driving. It fluctuates, but usually hovers in the low- to mid-13's
Old 04-08-2010, 09:32 PM   #13
That's about normal
Old 04-08-2010, 10:42 PM   #14
shinlee
shinlee's Avatar
Drives: 07 liftback
with the car on, normal output should be 13.7 to 14.5
with the car off, the battery should be about 12.5
I used to manage an Autozone, and I've done god knows how many alternator checks. If you're getting 14.1 then you should be fine. It sounds to me like there may be an issue in the wires, something not connected properly or something of that sort. A loose (incredibly loose) belt will cause it to not charge properly, but just pull on the belt while it's off, and if there's a lot of play, either tighten it up or replace it.
Old 04-08-2010, 10:48 PM   #15
MGargano
The battery holds at ~12.5v when off, but the "normal output" for me is lower than 13.7- usually closer to 13.2-13.4. I'm not sure if those 1/10's of a volt are a cause for concern, really.
It doesn't hold steady at 14.1 for any extended length of time- low 13's are "normal" for me
I inspected the belt when I compared the pulley sizes- it was nice and tight, no play or slack at all.
Old 04-09-2010, 01:07 PM   #16
severous01
if you buy the underdrive set isnt the alternator smaller to compensate and it's actually over-driven?
my experience with underdrive kits any way...jsut the alternator, not pump or any others, jsut the alternator to compensate for slower belt speed
Old 04-09-2010, 09:05 PM   #17
cruz-gsr
cruz-gsr's Avatar
Drives: 08 Yaris Lift Back
thats what i normally get on mine
cruz-gsr is offline   Reply With Quote
Old 04-09-2010, 09:53 PM   #18
MGargano
I tightened the belt very slightly last night and today everything seems to be "normal"- between 13.7 and 14.2.
NST NonStopTuning Pulley Kits NonStopTuning NonStopTuning 19 11-08-2014 11:23 PM
FS: Blue Pulley Set Shijima Items for Sale by private party 12 09-18-2009 09:34 PM
NST (NonStopTuning) Ebay Feedback & Rating NonStopTuning NonStopTuning 0 07-19-2009 11:11 PM
Feeler: NST 10% Underdrive Crank Pulley - Gray Black Yaris Items for Sale by private party 10 04-29-2009 12:24 PM
NEW GROUP BUY: NST WP-Lite & ALT-Lite Pulley Kit (NonStopTuning) NonStopTuning NonStopTuning 266 09-29-2007 03:51 AM
