Old 04-29-2010, 12:16 PM   #1
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
What happened to brake pad change DIY?
just need a DIY for brake pads, thanks!
Yawesh is offline   Reply With Quote
Old 04-29-2010, 01:17 PM   #2
DFA
Compulsive Washer
DFA's Avatar
Drives: 08' AT Meteorite Metallic LB
Send a message via MSN to DFA
I think this is something I'd benefit from as well, I might have to change mine in no more than 2 or 3 months.
DFA is offline   Reply With Quote
Old 04-29-2010, 07:17 PM   #3
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
werd, i wonder wat happened to chinocharles, he got banned! he had the diy for brake pad change
Old 04-29-2010, 07:22 PM   #4
Black Yaris
der Zeck
Black Yaris's Avatar
front brake bad change is super simple.... I bet I could do it blind folded
Jack up car and remove front wheels
remove caliper bolts, I want to say they are either 10 or 13mm head bolts
the caliper with the pads installed should then "fold" out away from the rotor
remove brake pads, install new ones and reverse process
pretty basic stuff
Old 05-02-2010, 10:44 PM   #5
bankrobber
Drives: 2007 Yaris Hatchback
what about a DIY for the rear Drum brakes?
bankrobber is offline   Reply With Quote
Old 05-02-2010, 10:46 PM   #6
bankrobber
Does the piston compress in or do you need to turn it to compress to put on new pads.
I did 4 wheel disc brakes on a pontiac and the front pushes in with a C-clamp but rear disc needed to turn to compress.
Old 05-02-2010, 11:04 PM   #7
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Actually, he auto-banned himself... And he decided to remove all his DIY threads. Just setting the record straight...
Old 05-03-2010, 09:59 AM   #8
1stToyota
1stToyota's Avatar
Piston simply compresses. Be sure to suck some of the fluid out of the m/cyl first, or better yet, crack open the bleeder while compressing the piston.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 09:50 AM
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 09:24 AM
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 08:18 PM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 07:05 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 02:25 PM
