#19 |
![]() ![]() ![]() Drives: 07 Yaris LB Join Date: Aug 2007
I found some type of leak the other day after I changed my oil I looked like coming from the valve cover but I removed the plastic cover and I found that I spilled a little bit of oil when making my oil change.
#20 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
no spill . Use a funnel and quarts .
#21 |
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
Did the OP use a funnel? I find these new oil groups(ii + iii) used today to be more weep and leak prone than the old gunk used 7 year ago or more.
#22 |
wonder if those that are using a lighter oil such as 5w-20 or a 0w-30 should look for this leak along the back of the engine block on the left hand side where the timing chain cover is and runs from the top down to the oil pan ?
#23 |
removed the oil cap , lift the cover up , and used a flashlight to look for oil that may have been spilled during previous oil changes I've performed only to find it clean and dry as it was from the factory . So not my doing .
#24 |
JEFF69dini , the technician said that the " BALL BEARING " you described is the source of our leak for the '08 sedan and that it's associated with the head gasket . Dye was used in the engine to locate the source . There's a ledge ( part of engine block ) above the " BALL BEARING " that is inverted that catches the leaking oil and mixes with the road dust , etc. . Then below the ledge it forms into a smaller square bottom where the oil drop forms ( this is looking up to the upper right ( passenger side ) hand corner of the backside of the engine block from beneath the car ) . Using a flashlight is very useful to spot the oil . Did you ever find out anything of your dilemma ? THANKS
| How many bottles of engine oil do you add? | hans_fh | General Yaris / Vitz Discussion | 23 | 05-27-2007 08:59 PM |
| swap for 2zz-ge???? | yarisTOONR82 | Performance Modifications | 12 | 03-23-2007 07:15 PM |
| About Engine Oil Changing Manual | hans_fh | DIY / Maintenance / Service | 4 | 03-03-2007 10:20 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
