Old 11-18-2009, 07:10 PM   #55
Originally Posted by fsj2 View Post
I want to wire up some aftermarket LED driving lights. I want them to come when the car is in drive. Is there a easy place to connect them? 2010 5 dr HB. Thanks.
To have them come on when the car is "In drive" with an automatic transmission, you could tap the connector C27 on the transmission. The 10A Gauge circuit feeds through the Park/Neutral/Position Switch on the A/T to feed the indicator on the cluster and the ECM with the position of the A/T shift. For low power lights (LED lights under 1A) you could feed them directly. For high power lights (incandescents or HIDs) you would have the Drive indicator feed the coil of a relay, which would then have it's own power feed for the lights.
C27 is the 9 pin connector on the front of the transmission (by the shift linkage). It has a row of 4 and a row of 5 pins. The center wire (light blue) on the 5 pin row is the "Drive" indicator wire. It will have 12V on it when the shift is in drive. For ground, you can grab a chassis ground, like the ground bolt under the left headlight.
Old 11-24-2009, 02:04 AM   #56
charleschia1986
charleschia1986's Avatar
Drives: Yaris RUSH HatchBack
The connector (4K) on the upper left in this picture, is the feed to the map and dome lights. White with a black stripe ground, Pink is the "door open" switched ground, and blue is 12V fed from the DOME fuse.
Hihi, I already tested the wires tat u mentioned in the picture.. The blue wire does give constant 12v and the pink wire should turn on the lights with the door right?
I already tested the pink wire by multimeter and it will only give 12v when the door is closed.
So may I know what can I do in order to get 12v out when the door is open because I want my led to be on only when the door is open...
Thanks...
charleschia1986 is offline   Reply With Quote
Old 11-24-2009, 07:56 AM   #57
Thanks...
Use the pink as ground and the blue as your +12V.
Old 11-24-2009, 12:55 PM   #58
charleschia1986
thanks a lot...
i tried and it WORKS.....
thank scott
Old 12-05-2009, 02:33 PM   #59
zuberio
Joined 3/08 ... really
zuberio's Avatar
Drives: '07 Sedan
another useful tidbit for those wishing to wire in LED mirror covers, you can get the signals from each side here. This is for the big relay/junction box in the driver's footwell area.
This way you don't have to go into your engine bay to wire them up
Thankyou ThankYou THANKYOU!!!
zuberio is offline   Reply With Quote
Old 12-06-2009, 03:45 AM   #60
charleschia1986
thanks CTscott for ya Helpsssss,
here is the link of my Final product.
u may have a look.
http://www.yarisworld.com/forums/showthread.php?t=24210
Old 12-22-2009, 08:45 PM   #61
Fazulka
Drives: 2007 Yaris 4dr Sedan Base
Thank you, The Architect. I installed a remote starter today, first one i have ever done. It works great! I could not have done it without this thread.
Fazulka is offline   Reply With Quote
Old 12-22-2009, 11:23 PM   #62
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Hi all. Is there a place I can tap into the engine bay for turn signals besides the wires that lead to the signal lamps?
Old 12-23-2009, 12:08 AM   #63
You can tap into the turn signal wires in the under hood fuse panel. On connector B13 (left connector in this picture), the light green and dark green wires in the upper row (next to the two red wires for my fog lights) are the turn signals. Light green is left, dark green is right.
Old 01-21-2010, 02:35 AM   #64
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
One more question, where can I tap in for the parking lights - the lights that go on just before I turn on the headlights?
Old 01-22-2010, 12:32 AM   #65
The White wire next to the blue and orange on the headlight stalk connector. You ground the wire to make the lights come on.
Old 01-22-2010, 02:50 AM   #66
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Sorry, should've made my question a bit clearer. I'm looking to see if there is one in the fuse box like the one pictured above.
Old 01-22-2010, 07:22 AM   #67
In the fuse panel, it is pin 3 on Connector B13, which is the green wire next to the two red wires in my picture above. If you don't have fogs installed, the place where the two reds are in my picture will be empty on yours.
Old 06-09-2010, 11:47 AM   #68
jonimac
jonimac's Avatar
Drives: Yaris Sedan 2010
Send a message via Yahoo to jonimac
Hi to all... just a noob here in M.E., just wondering if I tap the leads (+,-) of an LED light to the pink n blue from that pic above, will the new led light acts the same as the dome light? will the new led light dim to off as well upon turning off the ignition? Or just turns on when the doors were open? Sorry to much question. Need help where I can tap my led lights so that it behaves the same like the dome light, using its switch also to turn on my led lights underneath. Thanks so much. -jon
jonimac is offline   Reply With Quote
Old 06-09-2010, 12:02 PM   #69
If you tap the pink and blue, the LEDs will behave the same as them dome lights, provided that you leave the dome light switch in the "Door" position. If you manually switch the dome to "On", with the doors closed, the LEDs won't light up with the dome.
Old 06-09-2010, 05:56 PM   #70
jonimac
jonimac's Avatar
Thanks CTScott... got the idea!
Old 09-21-2010, 04:42 PM   #71
geniusmiki
Drives: Yaris 1.4 D4-D
hi can someone please tell me what are these cables found under the hand brake?
it's an european model.
thanks
http://img337.imageshack.us/g/19072009030.jpg/
geniusmiki is offline   Reply With Quote
Old 09-21-2010, 09:22 PM   #72
thanks
The black one is for the Door lock receiver. Does your Yaris have a manual or automatic transmission. If it's a manual, then the other two are for the A/T shift illumination and for the shift lock control ECU.
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 04:55 AM
New Yaris race car Jason@SportsCar Tracking, Racing, Auto-X Forum 83 11-01-2012 03:32 PM
