The Last Baron
Drives: 09 Polar White HB Join Date: Jun 2009
fog light wiring
Does any one sell just the wiring for the fog lights?
i already have the fogs, many switches and relays, all i need is the wiring. Thanks
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires! | UR 19mm sway | |
i have some here What part of the wiring are you after .
from the lights to the under bonnet fuse box , do you have the factory relay . ![]() let me know what you need . |
The Last Baron
well to make it easier im looking for the entire wiring kit, fog lioght to the bonnet fuse box and everything inside the cabin.
Theres no wiring in the cabin apart from your switch , (which you say you have )
i can send you the parts to make any 3 pin switch plug and play and a wiring diagram |
The Last Baron
when i say switch i mean i have a generic toggle switch. I think i saw some one who had one like that( ctscott ithink)
Okay so you want , The engine bay wiring , and for it to plug into the fuse box , under the bonnet .
Inside the car you want the factory relay and the aftermarket kit switch that will plug and play if that is correct your looking at $48.US Shipped complete with instructions . This loom will only plug into H11 Foglight Bulbs as per the factory . |
The Last Baron
check pm
no Problem , as i PM'ed back .
micro Image should have these Kits available soon . |
| How many forum posters does it take to change a light bulb? | silver_echo | Off-topic / Other Cars / Everything else Discussions | 25 | 06-27-2011 01:50 AM |
| Part #s for Fog Light install? Can anyone who works for Toyota confirm? | IsLNdbOi | Cosmetic Modifications (Exterior/Interior) | 73 | 12-23-2010 05:15 PM |
| test fit 06-07 Yaris 4 door fog light | winson | California | 15 | 01-13-2009 08:25 PM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 10:42 AM |
