Old 04-21-2009, 04:54 AM   #1
IsLNdbOi
IsLNdbOi's Avatar
Part #s for Fog Light install? Can anyone who works for Toyota confirm?
I would like to install fog lights on my '09 5-door LB, but need to find all the correct parts.
I've searched and have found different part numbers for each part I need.
Can anyone here who works for Toyota confirm each part number is correct for the '09 5-door LB?
New headlight stalk w/ fog light switch (combination switch):
84140-52151
Fog Light Relay:
90987-02027 ?
or
90987-02012 ?
Fog Light Shroud (Left):
81482-52260 ?
or
81482-52250 ?
Fog Light Shroud (Right):
81482-52330 ?
or
81481-52320 ?
Old 04-21-2009, 05:58 AM   #2
1NZYaris1
1NZYaris1's Avatar
If you want to save some cion talk to Garm at microimage ,
he is now selling his kit's with the correct relay + the wiring to plug into
the relay box under the bonnet.
all you will need then is the stalk , because if i am correct the 08 sedan foglights are the same as the 09 L/B.
Left: 81482-52250
Right: 81481-52320
Old 04-21-2009, 06:05 AM   #3
IsLNdbOi
IsLNdbOi's Avatar
I'd still need the fog light shrouds since his kit is specifically for the 06-08 LB. The '09s have changed a little bit. Some wiring is different (ex. tail lights, aux jack, etc.) and the fog light shrouds are different.
That's why I'm asking if anyone who works for Toyota could check for me. I could buy a fog light kit for the lights then get the correct parts from Toyota Parts Cheap.
Old 04-21-2009, 06:40 AM   #4
1NZYaris1
1NZYaris1's Avatar
The fog light shrouds are the same as the 08 Sedan ,from what i have seen .
Old 04-21-2009, 07:04 AM   #5
IsLNdbOi
IsLNdbOi's Avatar
I'd still like to have the part numbers for the parts meant for the '09 LB.
Old 04-21-2009, 09:45 AM   #6
spookz
JDM yO!
Drives: '09 3dr. 5-spd
They appear to be the same shape at a glance with the 08 sedans but when looking into closer detail, I believe they're different.
I can try and check for you if you are able to hold until the end of this week..
Old 04-21-2009, 11:47 AM   #7
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
STALK: 84140-52151
RELAY: 90080-87026
SHROUD LH: 81482-52260
SHROUD RH: 81481-52330
Old 04-21-2009, 12:50 PM   #8
DerFlosser
DerFlosser's Avatar
STALK: 84140-52150
RELAY: 90080-87026
Stalk p/n is wrong. It should be 84140-52151 (08+)
DerFlosser is offline   Reply With Quote
Old 04-21-2009, 01:14 PM   #9
BLAZINBLUEVITZ
fixed......
Old 04-21-2009, 02:13 PM   #10
Lafiro
Drives: 06 Yaris Sedan
What about for an 07 sedan?
Thanks.
Old 04-21-2009, 03:31 PM   #11
IsLNdbOi
IsLNdbOi's Avatar
Thanks guys. BlazinBlue, is this what is shown on Toyota's official parts list?
Old 04-21-2009, 03:33 PM   #12
BLAZINBLUEVITZ
yes
Old 04-21-2009, 03:40 PM   #13
IsLNdbOi
IsLNdbOi's Avatar
Is that the same part number for the fog light relay used in the '07 / '08 LB?
Old 04-21-2009, 04:03 PM   #14
BLAZINBLUEVITZ
yes but number i listed is superceeded from old one......
Old 04-21-2009, 04:10 PM   #15
IsLNdbOi
IsLNdbOi's Avatar
So same physical part? Just want to make sure because when I purchased fog light parts for my '07, I got two of the fog light relays for less than $50. At Toyota Parts Cheap, the price for the relay part number you listed is over $60 for just one.
The one I got before at Toyota Parts cheap can be found by going to:
http://www.trademotion.com/partlocat...?siteid=214001
Year: 2007
Make: Toyota
Model: Yaris
Electrical -> Electrical Components -> Relay -> Fog lamps
-> Fog lamps - Instrument panel - Instrument panel
Old 04-21-2009, 04:13 PM   #16
BLAZINBLUEVITZ
SAME PART different numbers different prices. but you understand this already so we're goody.....
Old 04-21-2009, 04:19 PM   #17
IsLNdbOi
IsLNdbOi's Avatar
What about the stalk / combo switch? Same part, different part numbers as well?
The part number above for the stalk / combo switch costs much more than the stalk / combo switch listed for the '07 / '08.
Old 04-21-2009, 04:25 PM   #18
BLAZINBLUEVITZ
once again it looks like same part but different numbers and different prices.
Fog light install 07yaris_fe Cosmetic Modifications (Exterior/Interior) 10 07-20-2010 01:18 PM
Looking for the Toyota Fog Light install RocknRollRon DIY / Maintenance / Service 33 06-13-2010 06:46 PM
srs / airbag light after head unit install? KwonSau In Car Entertainment + Electronics (audio / video / alarm) 7 12-24-2008 02:04 AM
