Old 06-02-2010, 02:13 PM   #55
ddongbap
Well if a supercharger is in the future, then I take back my comment about not getting a headerback exhaust. However, I wouldn't get it until after you have the S/C on or sometime soon before you put the S/C on. You wouldn't want to be driving around with 2.25" headerback exhaust and not have the S/C on. You will have no torque AT ALL! hehe
Well, that'll only be true on the low end. When top end kicks in, then it'll be better.
Old 06-02-2010, 02:21 PM   #56
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Yes, but it is no fun at all. Trust me. Before I had my blitz wired to be "ON" all the time, I would sometimes drive with the compressor off. That thing had no torque and was somewhat embarrasing to drive. You would have to give it more gas to get it moving and then that would make your muffler louder, yet you weren't moving anywhere. hehe
Old 06-02-2010, 03:57 PM   #57
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
hope this helps. it was 98* outside when i did this. The blue line is from yesterday. the yellow is from January (88* then)and before i had the res-back.
You would think i would have gained power but seems i have lost quite a bit. not sure whats the cause. Was at least expecting to gain a few from the res-back. Something is off somewhere.
I just changed my oil right before i went on the dyno tho so that maybe it but idk. I use to use valvoline synthetic, but switched to mobile 1 full synthetic. And also switch my octane to 87 rather than the 93 i use.
Mod List
AFE Intake
NST Crank Pulley
DC Header
TRD Axle back Exhaust With mandrel bent to resonator
1ZZ TB
I am running a bit lean. There is more power to be had if i got a tune but probably not worth it. Hope this helps paint a picture of what to expect.
Any questions hit me up....
Old 06-02-2010, 04:26 PM   #58
PETERPOOP
PETERPOOP's Avatar
hard to compare it when those are done so far apart and different weather conditions. i know you couldn't, but it would have been ideal to been able to do those back to back ( if you could install a resback exhaust with the snap of the finger ).
Old 06-02-2010, 04:52 PM   #59
Yoda
Yoda's Avatar
true but it still should have gained something rather than losing ~2whp
Old 06-14-2010, 11:23 PM   #60
sito
Drives: Toyota
Hi guys,
I just swapped the 1zzfe throttle body without the changing the chip and adjusting the idle screw...
No CEL for my car yet.. and the response is great....
But when i start my car this morning, the rpm shoots up to 2500 and after 2 mins, returns to 800... And when i turn on the aircon, the rpm shoots up to 1800 when the fan kicks in, and drops to 1000 when the fan stopped. These symptoms happen when my car is in stationary mode (or gear engages in P mode). Other than that, when i was driving in the city or highway, no other abnormalities found.
I was wondering is there anyone who do the mod faces the same problem as me? I'm not sure whether my pivot 3 drive (throttle controller) causes this? Cos my current pivot 3 drive is using harness for 1nzfe, but after the tb swap, i'm not too sure do i need to change the harness.
Hope you guys can help.
Thanks!!!
sito is offline   Reply With Quote
Old 06-15-2010, 09:04 AM   #61
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Originally Posted by sito View Post
Hi guys,
Thanks!!!
It's simply because the throttle body is designed to work with a bigger motor. When the ECU tells it to open to start the car, or that the A/C has turned on, it moves the throttle the same amount as the 1NZ tb, but because the opening is bigger, it lets more air in causing the higher idle.
Old 06-16-2010, 02:05 AM   #62
sito
Drives: Toyota
Thanks bro....
Do i need to swap the chip or adjust the idle screw, even though i have no CEL?
Sorry to bother you guys again... what's the reason for the chip swapping?
Thanks everyone....
Old 10-15-2010, 08:28 PM   #63
Astroman
Modded Moderator
Astroman's Avatar
So far over 3k miles on the TB swap and no problems. Weathers been getting colder so will see how that goes.
Viper Alarm Install gwasabi In Car Entertainment + Electronics (audio / video / alarm) 28 08-11-2010 02:57 PM
Idea I had, but I can't figure a way to make it work... kac Cosmetic Modifications (Exterior/Interior) 4 08-08-2009 09:17 PM
YarisWorld Marketing Idea *MAD DOG* General Yaris / Vitz Discussion 30 04-12-2009 05:46 AM
High pitched whine using stock head unit / aux input? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 8 02-02-2007 12:49 PM
