toyota
Hid bi xenon problem need to keep drl due to fogs
Need ur help guys unfortunetely the single bulb no xenon I bought did cause flicker weird thing is we tried it on one side and it works no drl no flickering nut once I connected both of them that's when he'll got loose flickering when I start the engine I need to keep drl due to fogs also have hid on fogs too now how do I get this bi xenon to work and also keeping drl relay due to fogs. Thanks for the input guys
just keep the relay, and disconnect the BLUE wire on from the DRL box..
toyota
And that will keep the fogs too I'll try that tomorrow thanks
toyota
can anyone confirm if i can just unplug the blue wire or does it have to be cut.. thanks
toyota
ok got it done by dicsonnecting the blue wire fr the drl relay..just a reminder for others..you dont have to cut it..just poke a mini flat screw driver to get the pin out for that blue wire.. no drl/no flicker. low and hi mechanical worked like a charm..
| Can anyone confirm if we can relay hid on yaris with drl? | marcus | Cosmetic Modifications (Exterior/Interior) | 0 | 06-10-2010 12:38 PM |
| Disabled drl and installed hids and now no fogs... | 604yarisrs | Cosmetic Modifications (Exterior/Interior) | 10 | 02-14-2010 12:26 PM |
| HID flickering problem - DRL fog - Problem solved. | IllusionX | Cosmetic Modifications (Exterior/Interior) | 9 | 10-01-2009 06:37 PM |
| xenon hid light bulb | lilman717 | Cosmetic Modifications (Exterior/Interior) | 7 | 12-19-2008 08:07 PM |
| HELP!! HID problem | 07yaris_fe | General Yaris / Vitz Discussion | 2 | 11-20-2006 06:00 AM |
