Old 01-13-2007, 08:54 PM   #19
Originally Posted by gonzo452001 View Post
I use OEM oil filter I just took it to the auto parts store asked for a filter wrench that would fit this filter and they pointed to where they wore got one of those cap types they are the best
NAPA didn't have any that could fit the filter. BAH...i have another 3k to find one of those caps. lol...
Old 01-13-2007, 08:55 PM   #20
Originally Posted by forpinks View Post
THE FACTORY USES AN IMPACT WRENCH TO TIGHTEN THOSE FILTERS...
OR SO DOES THAT TOYOTA MECHANIC I TALKED TO SAID.
I CHANGED MY FRIENDS OIL IN HIS BRAND NEW 07 COROLLA, AND BOY WAS IT A PAIN IN THE A.S.S. IT TOOK ME about 10 minutes to get the filter out, I needed to hammer that tool in just to get it out. good thing is he got mobil1 ready and a K&N filter with the nut so the next time i change it wont be such a pain...
i would get a K&N oil filter, but they're stupid expensive.
Old 01-14-2007, 11:28 AM   #21
gonzo452001
gonzo452001's Avatar
Drives: 3-door liftback blazing blue
I got my filter wrench (cap type) at pep boys works great most auto part stores keep them in stock
07 yaris LB 5-speed blazing Blue
07 yaris LB Auto Bayou Blue
rostra cruise control
oem style foglights
96tacoma 4x4 xcab I4auto
Weathertech vent visors
Scan GaugeII
gonzo452001 is offline   Reply With Quote
Old 01-14-2007, 06:08 PM   #22
LVAquaman
LVAquaman's Avatar
Drives: 2007 Yaris Hatchback
Does the "oil change light" go off automatically when you change the oil or do you have to reset it?
LVAquaman is offline   Reply With Quote
Old 01-14-2007, 06:23 PM   #23
i'll check them out before i do the next one. lol...i could always just use it, then return it. lol...j/k. i'd like to keep all my tools if they work.
Old 01-14-2007, 06:24 PM   #24
mine went off like normal. if it stays on, then all your oil must have sprayed out some how. happened to me when i didn't tighten my filter enough on my GTI.
Old 01-14-2007, 07:49 PM   #25
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
The flashing MAINT light does not go off after you change the oil... think about it.
There is a quick and easy reset procedure in your owners manual. Try searching here, its been posted a bunch of times.
Old 01-14-2007, 10:02 PM   #26
LVAquaman
LVAquaman's Avatar
Thanks again Chris!
http://www.yarisworld.com/forums/sho...ighlight=reset
Old 01-14-2007, 10:10 PM   #27
Chris07LB
Chris07LB's Avatar
No problem.
Old 01-14-2007, 11:37 PM   #28
Racer X-8
Races Little Red Wagons
Racer X-8's Avatar
Drives: red '07 Yaris liftback auto.
Beware of dribbling oil filters. Both times I did mine so far, the filter dribbled oil real bad when I loosened it.
Racer X-8 is offline   Reply With Quote
Old 01-15-2007, 01:56 AM   #29
i don't think mine is dripping...
Old 01-15-2007, 07:48 AM   #30
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Those Rhino Ramps look better than the ones I have because of the non-slip feet. Mine work fine for driving onto forward, but slip out from the rear 4 out of 5 times. They're impossible if the surface is wet.
Amazon.com has them for $33 - $40 with the chock blocks.
Old 01-15-2007, 11:01 AM   #31
Chris07LB
Chris07LB's Avatar
Remove the oil cap next time... it acts as a vent when removing the filter. Less mess.
Old 01-15-2007, 04:42 PM   #32
that's what i do. i'll even remove the dip-stick when ever i remember to.
Old 01-15-2007, 05:00 PM   #33
Racer X-8
Racer X-8's Avatar
hmmm, I'm pretty sure I did... can't swear to it though... but I'm pretty sure
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 10:22 PM
My first oil change RogueYaris DIY / Maintenance / Service 41 02-07-2007 08:41 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 09:16 PM
Dealership wants $64.99 for Oil Change? ScottFern DIY / Maintenance / Service 15 09-21-2006 11:49 AM
Oil change question Ryu DIY / Maintenance / Service 22 03-08-2006 12:21 AM
