Old 06-30-2010, 01:42 AM   #1
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Removing Power Steering/Replacing PS Rack with Manual Rack
Long story short I cracked/broke my steering rack. They have 'manual' racks advertised and im assuming that means no power steering. I'm wondering what needs to be done in order to properly remove the power steering system so i can use the manual rack.
Thanks
Heres a pic:
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 06-30-2010, 09:37 AM   #2
All 06+ Yaris have Electronic Power Steering. The electric motor is located up on the column, so that might be why so many eBay sellers list the rack as being "manual".
For conversion to manual, you can simply pull the EPS fuse, but the electric motor will offer some additional resistance to turning. You could probably pull the electric motor off of the steering column to alleviate that.
For replacing the rack, check out the power steering section of the service manual:
http://www.yarisworld.com/forums/showthread.php?t=1768
Old 06-30-2010, 10:30 AM   #3
auxmike
auxmike's Avatar
How did this happen?
Would'nt warr cover this??
Old 06-30-2010, 10:52 AM   #4
eii
Rides canyon walls
eii's Avatar
Cool, thanks for the info. So if I get one of these racks it will still have electronic power steering, correct?
I was gonna get this replaced by warranty, but when I went to the dealer my warranty was out by 1 month :)....
Old 06-30-2010, 11:10 AM   #5
Correct.
Old 06-30-2010, 11:52 AM   #6
ddongbap
I like how you added the :)
Old 06-30-2010, 12:15 PM   #7
eii
Rides canyon walls
eii's Avatar
lol I was so sad. I was gonna get the entire rack and tie rods (which I also need replaced) for free. $100 off ebay for rack and pinion + tie rods isnt that bad. I actually had been going up to GMR 4 times a week for 2-3 months with my rack like this. Also my hub/wheel bearing was completely destroyed and cracked too which I was running like that for a while too. It was louder than my engine. I replaced the bearing and hub a month ago and its going out again so I'm pretty sure my knuckle is bust too.
Old 06-30-2010, 03:40 PM   #8
ddongbap
I wonder how bad mine is. I've been to the track and many auto-x. But I never do regular checks.
Old 06-30-2010, 07:05 PM   #9
eii
Rides canyon walls
eii's Avatar
na, yours is good, trust me :)..
Old 07-01-2010, 08:24 AM   #10
yaris2010RS
yaris2010RS's Avatar
what did u do?
Old 07-01-2010, 08:48 AM   #11
Perhaps a little too much of this?
Old 07-01-2010, 10:26 AM   #12
eii
Rides canyon walls
eii's Avatar
Mmm, not something I like to brag about, but I've learned from my mistakes so I shall share..
Left turn, under steer, right wheel slammed into wall, rear flew up in the air. Replaced the lca and strut, but the + chamber was still present in right wheel. Assuming/most likely frame damage :). Also Im sure that the rack and pinion had cracked from the crash and finally broke off completely about 2-3 months ago. This accident happened almost a year ago.
Pics of the wheel
Pic of hub/wheel bearing
Pic of wheel, bad angle, but theres a few degress of positive chamber
Old 07-02-2010, 04:54 AM   #13
yaris2010RS
U HIT A WALL??!!! u hit an immobile object?? lol, bet u were having way too much fun, lol.
if u havent broken anything ur not having enough fun :)
any body damage? and i can almost assure u have damage on the other side from this.
Old 07-02-2010, 09:05 PM   #14
eii
Rides canyon walls
eii's Avatar
Dude, that wall came out of no where and moved in front of my car! Yeah i have too much fun and still doing so with my cracked rack :). My side skirt on that side got super scratched up and some tiny unnoticeable scratches on the rear door. My friend did the same exact thing at the same turn in his civic ef. He had some nice volks on, his wheel literally disentigrated. :)
From Manual Window/Lock to Power W/L eocintron Cosmetic Modifications (Exterior/Interior) 5 11-10-2009 11:31 PM
from manual to power windows/locks. TickleTimeTim Cosmetic Modifications (Exterior/Interior) 3 04-27-2009 01:28 AM
Well seems the F&*king Power Package with Manual is impossible in the States(Hatch) gaffo General Yaris / Vitz Discussion 28 07-15-2007 08:55 PM
How many 5-speed manual with power package? abcando General Yaris / Vitz Discussion 11 08-01-2006 10:54 AM
