Old 07-25-2010, 07:09 PM   #37
NH3R717
Drives: Yaris 3dr Hatch, White
have lowering springs?
could it be a loose endlink? maybe the endlink is binding on something? loose strut top nut?
with the one-nut setup on the front strut, the suspension moves a surprising amount....
crank your wheel all the way to whatever way you say clunks, then pop the hood....check out the top of your strut tower....i bet its sitting up....
the clunk COULD be the strut rubbing on the top of the strut tower as you slightly straighten out your wheel...
I am having the 'clunk' suspension problem. I had coils put on about a month ago and it was fine until a couple of weeks after. The sound happens only from the right side of the car and when I hit a bump or am turning left and hit a bump (more frequently like this). It also happens at a certain point when I jack up the right side of the car. I thought the strut cap also, and from my jack and listen inspection it doesn't seem to come from there but from the lower part of the car, like the sub frame. When people say 'retorque' the sub frame bolts are they looking for a certain value or just cranking down on the bolt more.
If it is a bolt problem I was thinking of removing, applying some hardcore locktite and retorqueing the bolts to spec or with in a reasonable range (I don't know what that range is rite now).
NH3R717 is offline   Reply With Quote
Old 07-26-2010, 12:12 AM   #38
nh3r717, sounds like its likely the swaybar endlink....tighten the nut at either end...
if you jack up the car and one is loose, itll clunk as it slides in the hole, but nothing will appear loose when the suspension sags all the way down...
you can see the top of the endlink attached to the left side of the strut in this picture....
Old 07-26-2010, 02:43 PM   #39
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
Originally Posted by Lucas13 View Post
Power Steering? The Yaris doesn’t have one...
yes it does
E.P.S
electric power-assist steering
any car owners should really read their owners manual and learn to appreciate
the workings of their car
OTA'sTOY is offline   Reply With Quote
Old 07-30-2010, 02:16 PM   #40
NH3R717
Good call on the sway bar link, that was it. Thanks.
Clicking Noise while Turning Bella Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 06-12-2010 02:13 AM
2006 Yaris clicking/clunking when turning heistp General Yaris / Vitz Discussion 1 10-13-2009 10:48 AM
Humming noise when turning the steering wheel!! Help?? mhkritzinger DIY / Maintenance / Service 7 09-28-2009 09:27 AM
Noise when turning acuraphile DIY / Maintenance / Service 3 07-22-2009 03:25 PM
Side Turning Signal ttufrosty DIY / Maintenance / Service 25 08-29-2007 02:33 PM
