#29 |
have lowering springs?
could it be a loose endlink? maybe the endlink is binding on something? loose strut top nut? with the one-nut setup on the front strut, the suspension moves a surprising amount.... crank your wheel all the way to whatever way you say clunks, then pop the hood....check out the top of your strut tower....i bet its sitting up.... the clunk COULD be the strut rubbing on the top of the strut tower as you slightly straighten out your wheel...
| Clicking Noise while Turning | Bella | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 06-12-2010 01:13 AM |
| 2006 Yaris clicking/clunking when turning | heistp | General Yaris / Vitz Discussion | 1 | 10-13-2009 09:48 AM |
| Humming noise when turning the steering wheel!! Help?? | mhkritzinger | DIY / Maintenance / Service | 7 | 09-28-2009 08:27 AM |
| Noise when turning | acuraphile | DIY / Maintenance / Service | 3 | 07-22-2009 02:25 PM |
| Side Turning Signal | ttufrosty | DIY / Maintenance / Service | 25 | 08-29-2007 01:33 PM |
