Old 08-05-2010, 10:49 AM   #1
henry33
Drives: yaris1.33
USB to yaris ?
Hi I have the stock radio with AUX in and my question is whether there is possibility to put USB port ?
thanks
henry33 is offline   Reply With Quote
Old 08-24-2010, 07:27 AM   #2
henry33
Drives: yaris1.33
will it be enough or will i work if I just change the aux connector near the hand brake for USB/AUX connector ? will the USB work ?thanks
Old 08-24-2010, 09:40 AM   #3
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
honestly if you want to do anything like that you might as well just go get an aftermarket deck that already has one. The stock deck is marginal at best, and anything you'd hook up through it would sound a ton better with a aftermarket deck.
The stock speakers are actually decent though.
Colin Chapman disciple
Old 08-24-2010, 10:25 AM   #4
henry33
Drives: yaris1.33
yes I know that the aftermarket will sound better nut I just want to change AUX input fot USB/AUX to gain the usb port but do not know if that will work ?
anyone done this ?
Old 08-24-2010, 04:19 PM   #5
jplelko
jplelko's Avatar
Drives: 2008 Yaris
No, i don't think it would work.
The aux port is just a analog 3.5mm stero jack.
USB is a 4 wire cable needing drivers on the host to work.
Like the others said if you want USB connectivity (e.g ipod or usb drive w/ mp3's) you need an aftermarket headunit.
jplelko is offline   Reply With Quote
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
Florida Yaris Meet! 6/23/2007! Sabretooth Southeast 13 06-05-2007 07:46 PM
