![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
I need Help on Idle Control
I have a problem regarding the IDLE control connection. Do anyone knows where I can find a diagram showing the idle control connector and it's terminal connections.
The connector is 3 wire : Red/Black - Yellow/Black - Brown I need this to connect it to the standalone ecu. Please note that I am referring to the 99up yaris idle control where the throttle is by cable and not electronic. Thanks |
#3 | |
Thanks for the pdf but I am still not understanding the diagram exactly. If you can help me identify which of the wires are positive and neutral and signal would be good I only found this related ( see attachment) Thanks |
From the PDF:
Brown is ground Red/black is the signal Yellow/Black is +12 |
Thanks CTScott I appreciate your help
From where can I get the full manual of this? Or at least do you have the page where it mention duty cycle and frequency or any related information on the Idle control signal specification? |
PM me your email and I'll send you what I have for your vintage of Yaris.
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| Warning - Broken control arm bolt! | CB900F2 | DIY / Maintenance / Service | 460 | 08-23-2020 05:54 PM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
