Old 01-21-2007, 02:07 PM   #19
Go4th
Go4th's Avatar
Drives: Yaris S Sedan color Flint Mica
87 octane or the recommended gas in your manual.
Use the recommended gas. The car is timed for the slower burning octane. The higher octane burns at a higher temp and in the long run will start causing that famous knocking noise in your engine. Sparkplugs and everything else will start feeling the pain of the higher heat and quicker burn, slowly but surely over time. Maybe once or twice a year you can run the higher octane to make you think you’re cleaning it out but it really don’t matter. Toyota did not design the engine to need all those extra additives that they put in the higher octane fuel. You’re wasting money for higher octane. Get the cheap stuff and keep more of your money in your pocket, Toyota recommends it! And your car will thank you for it.
Go4th is offline   Reply With Quote
Old 01-21-2007, 07:29 PM   #20
Black Yaris
der Zeck
Black Yaris's Avatar
Higher octane fuel actualy has retartant. And the cure for that "famous knocking noise" is to use higher octane fuel. The knocking noise if from using lower octane fuel, not higher.
Our cars can tell the difference between 87 and 93 octane. And when you state "Toyota recommends it" I do not find that entirely true, when they (Toyota) give an octane # for the car it is the minimum recommended.
Old 01-21-2007, 07:33 PM   #21
Yaris TTE JWRC
Drives: 07 5spd red Yaris HB 1.5L 16V
I agree with Go4th, i tried 93 many times before, it burns out quicker than the 87, I was just wasting my money, higer octane fuel are for high performance cars with a high performance engine, our 1.5L VVT-i is not a high performance engine, so you are just wasting your money
Yaris TTE JWRC is offline   Reply With Quote
Old 01-21-2007, 10:45 PM   #22
uncleyaris
jus worry about how clean the gas is and the detergents they may use!
UY
Old 01-22-2007, 11:32 AM   #23
stuffy
stuffy's Avatar
Drives: 06 yaris 5-dr le man
i've mentioned this in another thread,
on one of my regular drives, i go past a fuel truck re-filling station and i've noticed trucks from all of the major fuel companies filling up from the same tanks.
that would tell me that this is the exact same fuel they are using and selling under different brand names.
are any addities specific to companies added at the actual stations?
i would doubt it myself.
i've kept track of my mileage since the car was new, always using 87 octane from various companies, i have never noticed a difference in fuel economy depending on the brand of the fuel.
stuffy is offline   Reply With Quote
Old 01-22-2007, 07:27 PM   #24
gonzo452001
gonzo452001's Avatar
Drives: 3-door liftback blazing blue
I like sunoco here in Indiana .marathon has a bunch of trouble a couple years ago here they had to replace a bunch of sending units in peoples gas tanks
07 yaris LB 5-speed blazing Blue
07 yaris LB Auto Bayou Blue
rostra cruise control
oem style foglights
96tacoma 4x4 xcab I4auto
Weathertech vent visors
Scan GaugeII
gonzo452001 is offline   Reply With Quote
Old 01-22-2007, 08:38 PM   #25
Yaris305
Drives: Black
Idk i like w/e is cheapest to tell u the truth
Yaris305 is offline   Reply With Quote
Old 01-22-2007, 08:48 PM   #26
jthebeh
Drives: 2007 Nautical Blue Yaris Sedan
i go with the middle, not the cheapest or the priciest! ha ha sorry i dont know how to spell.
jthebeh is offline   Reply With Quote
Fuel Capacity ? ttufrosty DIY / Maintenance / Service 19 08-27-2013 12:14 PM
Increased MPG or HP anyone???? slvryaris Performance Modifications 55 05-27-2007 10:49 AM
fuel capacity xtrred General Yaris / Vitz Discussion 13 09-29-2006 09:21 AM
Consumer Reports on Ethanol Driver General Yaris / Vitz Discussion 6 09-01-2006 11:21 AM
Fuel / Temp / Mileage Gauge - Special LED Readings? bigsky2 General Yaris / Vitz Discussion 3 05-31-2006 09:04 AM
