Old 09-27-2006, 02:28 PM   #1
xtrred
Drives: 02 wrx wagon to 07 yaris sedan
fuel capacity
Hello all!
New member, 07 flint mica sedan from an 02 Subaru wrx wagon ( I still miss it ). Looks like a great amount of info around here and I look forward to investigating my new car on this site .
Anyway, I just but 11.511 gallons of gas in my sedan .
I thought that the Fuel capacity is only 11.1 gallons? I couldn't find a note about a reserve tank in the manual ( didn't look too hard though).
So, what exactly is the total fuel capacity for a 2007 yaris sedan?
Thanks
-M
xtrred is offline   Reply With Quote
Old 09-27-2006, 04:13 PM   #2
nsmitchell
nsmitchell's Avatar
Originally Posted by xtrred
Hello all!
Thanks
-M
Are you topping off? You can squeeze in more gas than the tank was designed for, but that is bad for your car (can ruin your vapor recovery system) , and bad for the environment. Always stop pumping when the gas pumps shuts off.
http://www.epa.gov/donttopoff/
Hope this helps.
Old 09-27-2006, 04:36 PM   #3
xtrred
Nope, just let it stop all by itself.
I learned this from the subie, as any topping off ended up on the ground!
I'm trying to calculate my MPG by gasoline added to tank VS. total tank capacity, and the 11.5 has totally thrown me for a loop.
-Mike
Old 09-27-2006, 04:48 PM   #4
FoEKuZ
FoEKuZ's Avatar
Send a message via Yahoo to FoEKuZ
imma topper offer...mmm..maybe i should stop.... i just dont like to have to pay $22.37...i rather pay $23.00 even.
FoEKuZ is offline   Reply With Quote
Old 09-27-2006, 05:17 PM   #5
ceres
Club Baby Seals
ceres's Avatar
Drives: Yaris Sedan
Is it a gas station you always go to? I remember one time seeing a news report on ones that screw with their pumps or the gas to steal money from customers.
Of course, I've also used pumps that are slightly broken and keep shutting off when I know I only have the tank about halfway filled.
And yeah, I also have a bad habit of aiming for the nearest .50
ceres is offline   Reply With Quote
Old 09-27-2006, 05:30 PM   #6
sroberts
sroberts's Avatar
Drives: 2007 Yaris Sedan
I use to top off as well. I have taught myself to just stop filling when it clicks off the first time. Makes life a whole lot easier and I believe the 11.1 is based on that first click. Like someone mention earlier its bad for the fuel recovery/vapor system because overfilling will block the fuel return ports. Gas can also retract and expand with heat and cold so it give it more room in the tank.
I am not allowed to put anything here because I do not have any ricey mods on my Yaris....
sroberts is offline   Reply With Quote
Old 09-28-2006, 12:46 PM   #7
xtrred
I didn't top it off, that's wh ythe 11.5 was odd.
Maybe they did rip me off?
Maybe the pump didn't stop in time?
Old 09-28-2006, 03:04 PM   #8
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Sounds like the station has maybe ripped you off
I had a station do this to me once.
After filling my motorcycle tank with 3.5 gallons
my bike only has a 2.8 gallon tank
That was a huge difference and very noticable. Had it been 3 gallons I would have never suspected anything but the gas station is still making a killing by gouging even a few cents per liter
Old 09-28-2006, 03:08 PM   #9
vodkalush
I drive a yarrrris
vodkalush's Avatar
Drives: 07 Sedan Polar White
I would call the BBB and report the a$$holes
will work for parts
Old 09-28-2006, 04:23 PM   #10
Yaris Dick
Drives: 07 Yaris LB, 06 VW GTI, 06 G6
There should be a regional contact for the Bureau of weights and measures. Depending on the state, they have regional inspectors who periodically go to gas stations and test the pumps to make sure they are dispensing the volumes they are charging you for. My Uncle is a regional inspector in PA and routinely doles out fines to gas stations who gouge consumers.
IF you honestly believe that's what's happening, I'd try to find a contact at the regional office and sic and inspector on them.
Yaris Dick is offline   Reply With Quote
Old 09-28-2006, 04:30 PM   #11
vodkalush
I drive a yarrrris
vodkalush's Avatar
if you really want to to be mean you could contact your local news station and let them of the situation...
not that anything would happen, but hey yah never know
will work for parts
Old 09-28-2006, 07:05 PM   #12
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Let the atorities know so they can at least check it out...
no point in jumpin' the gun, squealin' to the BBB or News until you know for sure they are gouging.
Let the proper athorities know you suspect something is up
Old 09-29-2006, 01:40 AM   #13
jeff_o
Drives: 07 Yaris
Send a message via ICQ to jeff_o Send a message via MSN to jeff_o Send a message via Yahoo to jeff_o
gas station pumps should be calibrated daily.
jeff_o is offline   Reply With Quote
Old 09-29-2006, 10:21 AM   #14
pxpaulx
Drives: Barcelona Red 5spd sedan
i'm a fity center myself.
pxpaulx is offline   Reply With Quote
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 09:07 AM
Consumer Reports on Ethanol Driver General Yaris / Vitz Discussion 6 09-01-2006 12:21 PM
Fuel Efficency argylesocks Suggestions - Feedback - Questions 4 08-29-2006 06:25 PM
What octane fuel is recommended? sroberts General Yaris / Vitz Discussion 4 06-09-2006 09:54 PM
Fuel / Temp / Mileage Gauge - Special LED Readings? bigsky2 General Yaris / Vitz Discussion 3 05-31-2006 10:04 AM
