Old 09-11-2010, 03:45 PM   #1
jeff69dini
Drives: 2007 Yaris Sedan 4 Door
Question heat shield over manifold came loose, help?!?
2007 Yaris Sedan, the heat shield over the manifold in the engine area came loose and rattles on the exhaust, only like a cm or 2 free play but enough to rattle
The 2 bolts on top are fine and still solid but the bottom 2 bolts I see there, I can't figure it out, looks like they never held it down in the 1st place unless something else rusted off
can anyone shed any light on this for me? thanks
jeff69dini is offline   Reply With Quote
Old 09-11-2010, 04:38 PM   #2
jeff69dini
actually looks like 4 x 10mm bolts hold the shield down, is that correct?
Old 09-11-2010, 05:45 PM   #3
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
^sounds about right
Old 09-13-2010, 10:00 AM   #4
jeff69dini
oh great, looks like the bottom 2 bolts are completely rusted and the metal bracket is completely gone, only 2 upper bolts held it, wonder if its ok to remove the shield altogether?
Old 09-13-2010, 10:18 AM   #5
Bluevitz-rs
If you have some copper house wireing, you can strip it down so it's bare copper and tie it to manifold with that. It's better to have the heat shield left on.
Old 09-13-2010, 10:33 AM   #6
jeff69dini
thanks, I'll try that, can I pick up one of the bolts holding it at a local hardware store as I ruined one? lol
Old 09-13-2010, 10:44 AM   #7
127.0.0.1
it is OK to remove the shield
but if you get stuck in traffic on a hot day you could
get some serious heat damage in the floor. best to get the heat shield fixed, or mcgyver your own.
Old 09-14-2010, 09:53 AM   #8
jeff69dini
hmm, I can't find one of those bolts that hold the shield on for the life of me, hopefully I don't have to go to toyota for it :P
Old 09-14-2010, 02:29 PM   #9
jeff69dini
ok ok, finally found a bolt, lol.........plus gonna use a huge clamp to hold the bottom part on......damn rust
rear exhaust heat shield Toy Yaris DIY / Maintenance / Service 7 04-19-2010 06:03 AM
LEDs and heat SaerinRhoe Cosmetic Modifications (Exterior/Interior) 10 01-02-2010 09:34 AM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
General Warning and Fuel Tank Heat Shield ttufrosty General Yaris / Vitz Discussion 8 05-31-2007 10:59 PM
