Old 05-17-2009, 09:13 PM   #1
Sabretooth
37HSSV
Sabretooth's Avatar
Drives: '11 Mazdaspeed 3
Turbo Manifold thread
Ok, heres my situation.
I am starting to put together a turbo kit for the Yaris, most of it will end up just being bits and ends here and there. Number one thing in mind is keeping costs below $2500 for an Intercooled setup.
My goals:
Cost at or just above $2500
No engine management
6PSI
Intercooled
Power goal: 160whp
Should be obtainable reasonably.
Step 1 was finding a turbo manifold for the car, so I started rooting around and found 2 options. Turbotoyotas.com manifold, then this sucker.
http://cgi.ebay.com/ebaymotors/03-06...Q5fAccessories
Its a cast iron piece, set for a T25/GT28 Turbo. OEM fitment. Only issue, its a Scion Xb/Xa Manifold.
Pics:
Any suggestions?
Old 05-17-2009, 09:17 PM   #2
gwasabi
Drives: 07 Blazing Blue LB
You get what you pay for! lol
Most Satisfying Crew
Serious Business...
MunkyWurks Garage - 8088488794
gwasabi is offline   Reply With Quote
Old 05-17-2009, 09:18 PM   #3
Sabretooth
37HSSV
Sabretooth's Avatar
Well I know that, just wondering if a cast iron part is better off than a welded one.
lol, just as a warning, Tamago is gonna have a field day with your statement if he finds it.
Old 05-17-2009, 10:57 PM   #4
Sabretooth
37HSSV
Sabretooth's Avatar
I might just buy it anyway...
Only way someone will know is to test it.
Old 05-18-2009, 12:26 AM   #5
turboecho2005
turboecho2005's Avatar
Drives: 2005 Toyota Echo
http://www.turbinetech.ca/produit_de...ac096c&lang=AN
You can ask about fitting it on the yaris... but this will also bolt up and its equal length...
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp
1987 Nissan Maxima - 40,000 original miles - Slammed
1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater
1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored
1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress
turboecho2005 is offline   Reply With Quote
Old 05-18-2009, 12:58 AM   #6
Remember how you had to remove your power steering to make room for that?
We have electronic p/s on our cars, so I think Jess' mani would fit just fine. Overkill for 6 psi though.
Old 05-18-2009, 02:21 AM   #7
gwasabi
i know that guy is always on my ass.
Serious Business...
Old 05-18-2009, 05:35 AM   #8
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
cast is better then welded can stand up to the heat but welded you can atleast reposition the angle. and the cast supposedly flows worse cause stay all ruff and whatevers inside not as clean as welded
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 05-18-2009, 10:20 AM   #9
Tamago
Tamago's Avatar
Drives: UZJ100
you bring it on yourself
Old 05-18-2009, 11:28 AM   #10
This manifold wont work, the A/C lines from the firewall would be in the way.
What if you don't have A/C lines? -- I don't.
Old 05-18-2009, 11:49 AM   #11
Tamago
Tamago's Avatar
Drives: UZJ100
What is you don't have A/C lines? -- I don't.
still don't understand why you'd do that...... delete something that doesn't need to be deleted..
Old 05-18-2009, 11:53 AM   #12
^ You've made that opinion clear before. If you ever ask a question instead, I'd be happy to answer it.
Old 05-18-2009, 11:58 AM   #13
Tamago
Tamago's Avatar
Drives: UZJ100
why?
Old 05-18-2009, 12:15 PM   #14
gwasabi
lol you dont have to comment on everything i say though. maybe like once in a while ignore me? lol
Thsat turbine tech one looks like its going up? i dunno lol
Serious Business...
Old 05-18-2009, 02:13 PM   #15
why?
1. I never, ever use my a/c so i have no need for it.
2. I'm saving 18 pounds of weight and clearing out the engine bay.
3. I'm trying to squeeze every horsepower I can out of this motor, and however small, this will make a difference. (yes, I know there are a lot more things I can do in this regard)
4. This gets the condenser out of the way of the radiator, easier to fab/install a custom radiator later.
5. I'm also converting the water pump to electric, so I want to see what the car is like with just two pulleys.
6. A panda on the hood is not "needed" either, but it's what you like -- this is what I like.
Old 05-18-2009, 03:40 PM   #16
Tamago
Tamago's Avatar
Drives: UZJ100
i ignored your original comment, didn't i?
Old 05-18-2009, 03:54 PM   #17
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Back on topic....
You can get the bends and turbo flangers here:
http://www.jgstools.com/turbo/index2.html
You would only need take out the OE exhaust manifold and take it to a shop to have the engine flanger done and welded to the rest...
You can duplicate the manifold design from Turbotoyotas (Cali's manifold) simple and functional.
Sure an EL mani is cool... but hard to fit on a Yaris and not really needed for the low boost levels this engine will ever see...
... And regarding the Cast vs welded tubular design.
Cast manifolds will always beat the tubulars on reliability and longevity that's why must of the OE turbo cars use as cast manifold. nothing wrong with them.
Tubular welded manifolds will usually flow better and provided more power... plus they look nicer.
But then again, all this is irrelevant at the boost levels this engine will see...
Old 05-18-2009, 06:05 PM   #18
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
why intercool it?
might as well make things easier and not intercool.
it'd be a lot cheaper too.
Russelt3hPirate is offline   Reply With Quote
Chino's Turbo Thread ChinoCharles Forced Induction Forum 299 03-17-2017 08:01 AM
GI: Turbo Manifold ChinoCharles Forced Induction Forum 4 04-13-2009 01:42 AM
xa/xb Turbo manifold for Custom set up CASTREX Forced Induction Forum 1 01-21-2009 02:43 PM
Why industries turbo manifold? anonymous user Forced Induction Forum 33 12-07-2008 01:11 PM
