C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
What size are 1ZZ-fe injectors?
I have injectors from a 98-99 corolla and I need to now what size they are in cc. Thanks
Drives: "Burning It Down GTX2860RS XB" Join Date: Sep 2010
They're around 200cc, but hey I told you I would get you those injectors as soon as I get in. So don't go wasting your money. Those Precision Injectors I have are 380cc and cost around 450.00. You will not find a better injector than Precision. they are flow matched, meaning you will get exact amounts of fuel per cylinder.
Merry X-mass XBG |
240-260cc.
I'm thinking they're most likely 260cc though. |
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
Take them to a place that can flow them. Guessing is not the way to go. I can assure you that the 1ZZ injectors I have flow 220cc. But they came from a Toyota Celica not a Corolla.
xB: 380cc's are too big for our use. I have the 1ZZ's & they run very rich. |
#5 | |
C'est la vie
1zz must be larger then 200cc though. I just want to program my FIC correctly. |
Understandable dude, didn't want you to spend undue money.
Rock-on XBG |
C'est la vie
Three guys three answers
And you don't have to run the full duty cycle of the 380cc injectors, thats what your fuel management is for.
I would hope with the AEM/FIC you could control a 380cc injector. XBG |
C'est la vie
Pimp,.....I'll make a personal call to Greg Nakono over at AEM for you. I'm pretty sure you can control those 380cc injectors. Then you'll also have room to grow.
I'm 680cc yeah...I have full-standalone but controlling a injector shouldn't be an issue. XBG |
C'est la vie
I guess I will try changing to 220cc and see where my AFR is
Thats what I thought.
Never tell me something is too big...I'll make fit and work anyways XBG |
C'est la vie
I know the FIC can handle it and I know how to calculate for larger injectors. I was just looking for flow rate on 1ZZ 98-99 corolla injectors
C'est la vie
The FIC is awsome I am learning so much by making my own map.
C'est la vie
This is the part number if that helps?
C'est la vie
Someone should make a injector flow chart with toyota part numbers. Mabe a bench flow testing master like cdydjded.
http://injectorrx.com/densotf.html here you go.
http://www.fuelinjector.citymaker.co...INJECTORS.html Last edited by kou; 09-29-2010 at 01:15 PM. |
C'est la vie
Thanks so much for the link. Unfortunatly my part number is not listed. The closest one 23250-22040 says 255cc. Any way I put them on my car and it still goes lean. These injectors seem about the same as stock. I recalibrated my FIC map from 200cc to 220cc and my AFR got leaner across the entire rpm range. So not big enough. For now I returned back to 200cc calibration, until I get bigger squirters. O well it was worth a shot. Everyone should save those links.
| 1zz injectors suit the S/C just fine | LtNoogie | Forced Induction Forum | 51 | 04-30-2016 10:11 AM |
| FS: 05 1zz t/b and injectors | OTA'sTOY | Items for Sale by private party | 4 | 06-03-2010 08:07 PM |
| 1ZZ Injectors on NA Setup | MGargano | Performance Modifications | 14 | 04-22-2010 01:02 AM |
| Exhaust Pipe Size (Tamaņo del tubo de escape) | carlosh | Central and South America | 11 | 08-02-2007 04:15 PM |
| swap for 2zz-ge???? | yarisTOONR82 | Performance Modifications | 12 | 03-23-2007 07:15 PM |
