#19 |
![]() Drives: Vitz 2005 model Join Date: Jan 2010
the electrician said that come tomorrow I will diagnose with computer....I have no idea that what is the battery voltage before and after ...my vitz is japanese made it has P,R,N,D,S,B .... its fully automatic ... I dont know more about auto trans...hope u can check my car live :(
#20 | |
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris S Sedan 5-Speed Join Date: Oct 2008
I was going to recommend taking it to the dealer. I assume there are competent technicians there? Since you own a Toyota, is there not a dealer? This is usually the type of problem people can't fix themselves. Computer/electrical systems in cars are the most complicated aspect of them and require specialized expertise and equipment to even find out what's wrong, never mind to fix it. Many times, the whole interior has to come apart. This is definitely one of a kind for the Yaris - the most trouble free car ever. Good luck. |
#21 | |
#22 | |
#23 |
at last I found a good electrician ...he figured out the problem...the problem was with th rear view camera...its wires somehow got attached with each other which caused the whole fuse box to explode ...he replaced all fuses and repaired the fuse box ...now every thing is working fine again :)... toyota electricians sucks..they said that there is the problem with brake switch which sounds wiered to me.. anyway thanks alot for the help you guys specially CTScott :)
| Weird Clicking Sounds | Itsnhi | DIY / Maintenance / Service | 6 | 12-22-2009 06:30 PM |
| Weird door locking problem, electrical? | davembfan | General Yaris / Vitz Discussion | 19 | 09-30-2009 02:50 PM |
| weird knock at full lock | YRX | DIY / Maintenance / Service | 9 | 06-18-2009 10:18 PM |
| Weird question, needs some help! | hshi | DIY / Maintenance / Service | 13 | 01-07-2009 10:54 PM |
| A/C smelling weird? | Yaris_PR | General Yaris / Vitz Discussion | 11 | 08-04-2006 08:26 AM |
