Old 10-18-2010, 10:33 PM   #19
TickleTimeTim
Free Mustache Rides
TickleTimeTim's Avatar
Drives: 2007 Yaris HB
what is this 3 pulls business? sorry, stupid question im sure. after doing a little research, i keep seeing 3 pulls for $75 locally.
Club SHIFT
Old 10-18-2010, 10:54 PM   #20
It's totally possible, I've seen a few cars that have dyoned with more power than they should from stock factory numbers
Really? 16-20% better? I'd like to see a concrete example that you've "seen".
Old 10-18-2010, 10:57 PM   #21
anyways, a "pull" is one run on a dynamometer at full throttle in one particular gear, measuring power and torque throughout the rpm range, up to redline.
Usually a few pulls are done to get a consistent or "best" result. Or, a tuner does a session of several runs while tuning the car for whatever the desired result is.
If I didn't get that quite right, please correct the details.
Old 10-18-2010, 11:17 PM   #22
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
The only dyno in New England runs you 250 an hour. You get as many pulls as you want, but you still pay the minimum 250.
Old 10-19-2010, 04:52 AM   #23
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Well that explains it, no way you were in 3rd or 4th if you pegged the speedo. That explains the freakishly high #'s......
wait. so a different gear ratio will give you different numbers? ill ask that guy later after work today. if thats the case, ill see if he will throw in an extra dyno for me in 3rd gear and see the difference. but ill still try to hit up jacksonville this friday if i can make an appointment to get another dyno comparisson..
Old 10-19-2010, 05:06 AM   #24
ilikerice
ilikerice's Avatar
Manuals are usually tested in 4th gear (one the 1:1 ratio) and autos in 3rd gear (usually 1:1 ratio)
quote posted on a ford forum.. but im also seeing some who posted 3rd, but again, cant believe everything u read on the internet..
here is a link to a guy who did a review on the dyno dynamics machine who compared to others.
http://www.efi101.com/forum/viewtopi...43172d975a61b9
Old 10-19-2010, 06:54 AM   #25
ddongbap
Thats so complicated. Just have ur own baseline. Then dyno it the same way every time you mod your car. Dyno numbers don't mean ish when you're on the track.
Old 10-19-2010, 08:24 AM   #26
fnkngrv
fnkngrv's Avatar
Even if people track their car many times people like to know what they truly are getting for their hard earned dollar when buying performance parts. Plus it is always nice to be able to tell someone an honest number if asked rather than just saying, "Dyno numbers don't mean ish when you're on the track." Also as a point of reference the LTA (Loring Time Association) here requires you to provide at least something so that they can gauge certain requirements at their track events.
Dyno results PETERPOOP Forced Induction Forum 28 12-09-2009 11:01 AM
NST Sponsored Dyno Day In Houston NonStopTuning NonStopTuning 24 10-05-2009 02:26 PM
dyno day psychopinay42 California 1 08-03-2009 03:42 AM
Dyno and Videos ruimond Photo-Video-Media Gallery 23 02-01-2009 07:34 AM
WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! WRLEO Sponsors Classifieds Area 0 02-22-2007 10:14 AM
