Old 10-19-2010, 05:07 PM   #19
severous01
you can do some research on that bearing/hub combo. find a hub w 5 lug and press out your hub...i know it's a sealed bearing but it was assembled somehow. you could also buy the bearing since you're going through all the trouble and it's just another step to press in/out the old bearing.
press out the old hub, press in the new hub...no biggie. specially for someone who has to 'modify everything to fit anything'...per se'.
i think that the hubs on a corolla will fit just fine. i'm sure toyota is smart enough to use the same bearing/designs especially if it works...and just change the hubs out.
long story short, i used a chevy truck hub/bearing on my jeep cuz it was 30 bux cheaper. the only difference was the lug size. i pressed out the 6-lug hub and pressed in my old 5-lug hub just fine. and instead of replacing my bearings every 6 months they lasted another 18 and i sold it with them still in there.
Old 10-19-2010, 07:51 PM   #20
big lo
big lo's Avatar
Drives: 2007 VIOS
Originally Posted by revolution View Post
Theres no TireRack in Malawi, LOL its in the middle of Africa and no such thing as a Scion here...!
Big lo, any idea how they change to 5-lug?
Sure buddy I'll get the info to you ASAP I have a buddy who did it and is rocking the Rav 4 rims not my taste but a good job at that, from what I know the stock hub is very easy to take off and you need a special rachet to do so, I'll pm you with more info
Old 10-20-2010, 05:10 AM   #21
revolution
Drives: 2009 JDM Toyota Vitz
Went to a Breakers Yard today, and managed to find a new Corolla there... Front end seems OK, and the Toyota Schematics show a similar setup, only problem is the Rear now because the Vitz has Drums at the Rear, but the Corolla has Discs... Grrrr!!!!
2011 JDM Toyota Vitz RS
NCP91-AHMVK
Keyless-Go,8 Airbags, Pioneer AVH-P4150DVD, Reverse Camera, Nokia Bluetooth Kit, Pioneer 6.5" 230W Split System in Front, 6000K HIDs in Headlamps, 6000K HIDs in Foglamps, Afe Intake, 17" Advanti Toro Rosso Alloys with 205/45/17 Yokohama R1 Tyres, 40mm Modellista Lowering Springs...
revolution is offline   Reply With Quote
Old 10-20-2010, 06:02 AM   #22
ddongbap
I have a sneaking suspicion that the Scion XD rear trailing arm will fit.
Old 10-20-2010, 07:34 AM   #23
revolution
If I go the Corolla Option, what would happen if i transfered the Rear Disc Brakes setup across to the Yaris? Would it just connect to the existing Brake lines? If so, it could be a combo way of getting 5-lug and rear discs! Hmmmm!!??
NCP91-AHMVK
Old 10-20-2010, 11:23 AM   #24
cdydjded
Drives: Yaris LB Turbo
Hi Everyone,
I live in Malawi and it is very difficult to get anything in the way of decent Alloys here in a size above 15"...
I would like to fit a set of 17" Alloys on my Vitz, but can only source 5-Lug types here in that size...
Is there a way to change to 5-lug? Would I maybe have to change my rear drums and front discs to that of maybe the New Corolla (which is a 5-lug) to then make it fit?
Sorry if this offends anyone but out here we pretty much have to modify everything and anything because there are no tuning places or accessory stores......
Go to my website, www.traklitewheels.com, see if you like anything, I have 17' 4 hole wheels.......
Old 10-20-2010, 02:24 PM   #25
revolution
If someone could just find me a set of the 17" OEM Yaris TS Wheels it would make my YEAR!!!!!! LOL
NCP91-AHMVK
Old 10-20-2010, 02:58 PM   #26
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
i wanted 3 bolts..if its possible less lugs and less weight..lolz...
Old 10-20-2010, 03:25 PM   #27
33OH
Drives: '08 Yaris
http://cgi.ebay.com/ebaymotors/ws/eB...19988011079557
Old 10-20-2010, 03:59 PM   #28
revolution
These are the ones I'm looking for....
NCP91-AHMVK
Old 10-20-2010, 04:38 PM   #29
big lo
big lo's Avatar
Drives: 2007 VIOS
In microimage they sell the rear brake convertion, and those rims look nice
Old 10-21-2010, 01:53 PM   #30
revolution
Given up on the 5-lug conversion, after seeing the amount of work required to transplant the Corolla Hubs and Brakes across, just not motivating enough!!!
Still on the hunt for the above Yaris TS 17" Wheels though, ANYBODY have a set of these that they want to sell? Surely some of the TS owners are doing the aftermarket wheel thing??
NCP91-AHMVK
Old 10-21-2010, 02:21 PM   #31
33OH
Drives: '08 Yaris
I know, we just don't have that version in the US. Was linking the closest thing I could think of and saw they shipped internationally.
Old 10-21-2010, 04:30 PM   #32
severous01
in order to go from drum to disc you need to change out the proportioning valve. if not you'll wear the rears wayyyyyy faster than the fronts. it's set up that way to overcome the springs in the drums so the disc doesnt engage first....no springs, rears will engage first.
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal hasher22 DIY / Maintenance / Service 88 03-06-2014 06:40 AM
$86.44 for oil change? I feel screwed behour General Yaris / Vitz Discussion 98 01-04-2010 07:10 PM
MJ dead 90tsi Off-topic / Other Cars / Everything else Discussions 28 06-26-2009 02:20 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
