Old 10-18-2010, 06:28 AM   #1
revolution
Drives: 2009 JDM Toyota Vitz
Can I Change to a 5-Lug??
Hi Everyone,
I live in Malawi and it is very difficult to get anything in the way of decent Alloys here in a size above 15"...
I would like to fit a set of 17" Alloys on my Vitz, but can only source 5-Lug types here in that size...
Is there a way to change to 5-lug? Would I maybe have to change my rear drums and front discs to that of maybe the New Corolla (which is a 5-lug) to then make it fit?
Sorry if this offends anyone but out here we pretty much have to modify everything and anything because there are no tuning places or accessory stores......
2011 JDM Toyota Vitz RS
NCP91-AHMVK
Keyless-Go,8 Airbags, Pioneer AVH-P4150DVD, Reverse Camera, Nokia Bluetooth Kit, Pioneer 6.5" 230W Split System in Front, 6000K HIDs in Headlamps, 6000K HIDs in Foglamps, Afe Intake, 17" Advanti Toro Rosso Alloys with 205/45/17 Yokohama R1 Tyres, 40mm Modellista Lowering Springs...
revolution is offline   Reply With Quote
Old 10-18-2010, 09:00 AM   #2
markitect
If you guys have the Scion XD it's probably your best source for parts, because a lot of it is the same as the Yaris. I'm not sure how much you'll need to swap though.
markitect is offline   Reply With Quote
Old 10-18-2010, 09:34 AM   #3
MUSKOKA800
MUSKOKA800's Avatar
Contact TireRack. They'll get the correct 4x100 stuff to you. Shipping charges should be less than converting your car to another spec.
Old 10-18-2010, 11:03 AM   #4
big lo
big lo's Avatar
Drives: 2007 VIOS
Out in PR a lot of the Yaris vehicles are doing just that and using RAV4 rims looks cool, go for it
Old 10-18-2010, 02:59 PM   #5
revolution
Theres no TireRack in Malawi, LOL its in the middle of Africa and no such thing as a Scion here...!
Big lo, any idea how they change to 5-lug?
NCP91-AHMVK
Old 10-18-2010, 07:05 PM   #6
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
they make things to do that, grr I can't remember what it is called. But on some cars swapping to different lug patterns is common, maybe if you search around on the net you'll get lucky and find something.
Colin Chapman disciple
Old 10-18-2010, 07:30 PM   #7
Black Yaris
der Zeck
Black Yaris's Avatar
You would need hubs from a Toyota Ist
Old 10-18-2010, 07:45 PM   #8
ddongbap
HOnda used to make 4lug and 5lug versions of the same car.
Old 10-18-2010, 09:33 PM   #9
cdydjded
Drives: Yaris LB Turbo
Yes you can, you would have to source the hubs, rotor, caliper & bracket from a Toyota car that came 5 lug. Hey Big lo, find out for us from someone there in P.R. Iv seen it done, just dont know what car the got the parts from...
cdydjded is offline   Reply With Quote
Old 10-18-2010, 09:58 PM   #10
Black Yaris
der Zeck
Toyota Ist (aka Scion xD)
Old 10-19-2010, 09:37 AM   #11
revolution
Seems like the Toyota Ist is a 4-Lug as well.....
NCP91-AHMVK
Old 10-19-2010, 09:49 AM   #12
The right way to do it would be to change the hubs, but the easy way to do it would be with wheel spacers that are also 4 lug to 5 lug adapters:
http://shop.adapterkings.com/4-Lug-t...g-to-5-Lug.htm
Old 10-19-2010, 10:40 AM   #13
revolution
CTScott... Thanks for that!
I have been searching online as well, seems like most of these kinds of adapters are like 2 inches thick... surely that will push my wheels out like a tank! LOL will contact Adapterkings and see if i can get something to work... ;)
NCP91-AHMVK
Old 10-19-2010, 10:53 AM   #14
The thinnest ones I've seen are 1" thick. If you are buying new rims, you can compensate for the thickness in the offset of the rim.
Old 10-19-2010, 11:43 AM   #15
revolution
Might I be able to skim a bit off the rim to compensate for the thickness of the adapter...?
NCP91-AHMVK
Old 10-19-2010, 12:09 PM   #16
I don't think so, without compromising the strength of the rim.
Old 10-19-2010, 12:09 PM   #17
33OH
Drives: '08 Yaris
As a DIY? Probably not.. If you have any wheel manufacturers around your area you may be able to get them to mess with it. (i.e. we have Diamond Racing Wheels in Wisconsin who will modify wheels.)
Old 10-19-2010, 01:53 PM   #18
revolution
I read somewhere that adapters can be found only 8mm thick, would be great if i could find some like that - the other option i am looking at is to change the rear hubs and front rotors to those of the latest corolla as it is now a 5x100pcd........ (?!) Might that be a better option?
NCP91-AHMVK
Tutorial : Speaker Changing, Headlight Painting, Center Control Colour,Panel Removal hasher22 DIY / Maintenance / Service 88 03-06-2014 06:40 AM
$86.44 for oil change? I feel screwed behour General Yaris / Vitz Discussion 98 01-04-2010 07:10 PM
MJ dead 90tsi Off-topic / Other Cars / Everything else Discussions 28 06-26-2009 02:20 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
