#37 | |
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Sep 2010
Hershey...keep us updated. I'm sure the job will get done right!
05' Echo Hatch - Greddy Supercharger - rear disc |
#38 |
Sent an e-mail with pics about our experince to the owner of the TOYOTA delearship where we had the gasket replaced and haven't heard a word as of yet . Also sent a letter to TOYOTA about our experience with the service center and the dissatifaction with our '08 and '10 YARIS .
#39 |
Well , another owner of a 2010 3 door (48,000+ mis. , drives about 1,000 mis. per week ) we know also has the same oil leak from the head gasket of the #1 cylinder as our 2010 and that of the 2008 before the head gasket replacement which is fine thus far . Know this by checking his engine last THURSDAY and it had some black soot ( dried from heat of engine overtime ) along with a small amount of fresh oil on my finger tip . After discovering this I cleaned the area thoroughly and went back to check earlier today to find more fresh oil on the tip of my fingers . Recleaned it and plan to recheck in a week or so . Yes . I did check to make sure no oil was spilled from previous fills of oil and none was found . We also went to local used car that had a 2008 YARIS 3 door with 47,000+ miles . Luckily the car was unlocked so I could pop the hood to check for the leak . That too had the sooty black oil residue in the same spot . Over a month ago I looked at a 2008 YARIS sedan with 28,000 miles at a dealer and that had the sooty residue . I always lift up the plastic engine cover of every YARIS I inspect to make sure no oil was spilled .
#40 |
We've been given a 8 year / 125,000 mile powertrain warranty ( Platinum ? ) for free by TOYOTA for the 2008
. That's a relief . We're likely to keep the '08 sedan until it craps out .
#41 |
![]() ![]() Drives: 2010 Yaris ce Join Date: Jan 2010
that's very strange of the 15 or so 1nz-fe engines I have worked on and checked over in the past week, I still have yet to see one that has any sort of leak like the one you describe. Glad you got the free extended warranty the engine will easily exceed that coverage with normal maintenance intervals.
#42 |
Got verification it's the PLATINUM . Hope to get the PLATINUM for free for the 2010 3 door after the head cylinder gasket is replaced in that .
#43 | |
. Hopefully it's not an epidemic . Been a royal pain in the .
#44 |
OK, I made an HD video of the area in question.
Have a look! http://www.youtube.com/watch?v=EVK_uBKotcU
#45 |
Thanks for the video . Can't get much more defined than that . Have to hook up the PC to the LCD t.v. for the HD and put it on loop . May even use the video as a screen saver .
#46 |
Glad you liked it!
Here's the camera I used to video it...
| DC Sports Header install and evaluation | Loren | Performance Modifications | 217 | 07-04-2017 06:40 AM |
| Megan Axleback Gasket | slothman86 | DIY / Maintenance / Service | 6 | 12-23-2009 09:00 PM |
| Oil drain plug gasket question | schleppy | DIY / Maintenance / Service | 7 | 04-17-2009 05:35 AM |
| Changing LED's In Projector Head Lights | whooppee777 | Cosmetic Modifications (Exterior/Interior) | 16 | 03-01-2009 02:07 PM |
| Req: Head unit suggestions. | xed | In Car Entertainment + Electronics (audio / video / alarm) | 21 | 08-09-2007 07:38 PM |
