Old 11-26-2010, 12:06 AM   #37
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
^ for sure!!!
Looks awesome. I still can't figure out why the intercooler has an offset outlet? It looks weird.
Old 11-27-2010, 12:34 AM   #38
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Thanks guys. This a very short clip of the turbo flutter that happens when shifting. Taken with a junk camera. Expect MUCH MUCH better quality videos once I am tuned.
I am running 14.5 (lean) during WOT, so I haven't been driving the car around that much. It also drives at 15.0 during normal driving conditions (a little lean), and idles from lean to rich. Definitely needs a new tune right. Waiting for the AEM tru boost controller to show up before the tune happens. Mind you, this is running with my supercharger tune that I still currently have. Not sure what kind of AFR numbers you'll get, pretuned, if you didn't have management from the start.
http://www.youtube.com/watch?v=BWiamyiPFhQ
Old 11-27-2010, 01:34 AM   #39
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Anything outside of boost, 13.5-16.0 is acceptable, mostly it tries to stay stoich at 14.7.
You are also running a non recirculated BOV it seems, you can see the AFR gauge go rich when the BOV pshhhts.
Boost you should be at 11-12.
Hope you get someone to tune it good for you!
Old 11-27-2010, 01:13 PM   #40
PETERPOOP
PETERPOOP's Avatar
Just pulled out the old spark plugs, look kind of worn, and the gap is at about 1.2 ( that was with the S/C ). Planning on putting on new ones (NGK Iridiums), any suggestions on a good starting point for the gap?
I'm also running meth injection under boost, will that also affect the gap?
I'm going to have the tuner gap them during the tuning session, but I don't know when I'll be able to get the car tuned. But for now, I am going to put some new ones in.
Old 11-27-2010, 02:07 PM   #41
PETERPOOP
PETERPOOP's Avatar
The 1.2 is mm, breaks down to like .045 (which is basically stock). But under boost, i was reading requires a smaller gap. Cali yaris is running .028 at IDK how many psi. I was thinking to set the gap at about .035 or something.
Any thoughts?
Old 11-27-2010, 03:00 PM   #42
.028 gap at 14 psi up.
At what boost level is your meth injecting? I tuned my car up to 14 psi before it needed the meth.
Old 11-27-2010, 03:43 PM   #43
PETERPOOP
PETERPOOP's Avatar
Put in the new spark plugs, set the gap at .035. It actually gave me better AFR. It is now running at about 10-11 AFR during WOT, and 14.7-8 during normal driving.
Here's a new short little clip of doing WOT. Click HD and full screen to see the wideband numbers better..
http://www.youtube.com/watch?v=8kXZRORS9rk
Right now I think I have the meth starting at 2psi. But when I get tuned, I am going to talk to the tuner to see when I should have it start.
Also, my current boost gauge is showing about 4.5 lbs of boost. Not too sure how accurate the gauge is. I thought the zage kit comes at 6-7lbs of boost? Going to be putting in a AEM tru boost digital boost controller in the near future. I'm going to set it at 8 lbs of boost.
Old 11-27-2010, 03:45 PM   #44
Nice!!
I have my meth start at about 6psi. I don't think you need it before that point.
The zage kit comes with 0.5 bar spring which is just a bit over 7psi.
Old 11-27-2010, 05:56 PM   #45
Nexus1155
Drives: Audi
.26-.30 gap i guess for when you boost. I guess .35 is ok. Watch for misfires, im surprised you didn't hear it breaking up before when it boosts like little pops everywhere.
Old 11-27-2010, 08:52 PM   #46
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
I had this problem. It disappeared as soon as I put a manual boost controller in though. Now I'm seeing 8ish during normal driving. The wastegate probably cracks around 5 psi and makes it hard to spool up fully.
How's your BOV situation? I watched the second video and can't really hear it. Kinda glad to see you're having fluttering as well... So far I've fully adjusted and loosened the BOV and it still always flutters.
Focus_Sh1ft is offline   Reply With Quote
Old 11-27-2010, 10:11 PM   #47
PETERPOOP
PETERPOOP's Avatar
Slow drive by..
http://www.youtube.com/watch?v=ZG5K3LgsJGw
Re gapped to .030
FocusShift: Good to hear about the boost situation. All I hear is the flutter from the turbo. Can't really hear the BOV. You should post a video of yours......
Old 11-28-2010, 02:38 PM   #48
Focus_Sh1ft
Slow drive by..
Re gapped to .030
Hm, on closer inspection that BOV sound you have is nothing like mine. That's why I didn't really pick up on it at first. I'll try to get a video this week... Tbh I don't know how to capture the sound on an automatic though
Old 12-05-2010, 12:38 PM   #49
PETERPOOP
PETERPOOP's Avatar
Just installed the AEM Tru Boost controller. Putting down about 7.88 lbs of boost. Loving the power. Can't wait to get it retuned. Just waiting for my HKS SSQV 3 BOV to get here.
http://www.youtube.com/watch?v=wHxZFGqow0c
Old 12-05-2010, 02:02 PM   #50
Tamago
Tamago's Avatar
Drives: UZJ100
sounds good, but why spend money on the SSQV?
Old 12-05-2010, 02:23 PM   #51
PETERPOOP
PETERPOOP's Avatar
I found a pretty good deal on the HKS bov and I wanted to try it out. I don't know the quality of the ZAGE bov, and supposedly the HKS bov helps out with performance.
However, unlike most people, I'm not really a fan of the high pitched noise the HKS bov makes.
Old 12-05-2010, 02:42 PM   #52
Tamago
Tamago's Avatar
Drives: UZJ100
there's no way a BOV can improve performance unless the BOV you're currently using is malfunctioning. but a good deal is a good deal, go for it! what will you have to do to modify to make it work?
Old 12-05-2010, 03:09 PM   #53
Focus_Sh1ft
^ We both believe the Zage BOV isn't working correctly and is still allowing compressor surge to happen.
Hey Peter, where did you mount your meth tank?
Old 12-05-2010, 04:08 PM   #54
Tamago
Tamago's Avatar
Drives: UZJ100
so you don't think the bypass valve is opening fully on throttle-lift?
isn't the whole idea of a recirculating valve to help prevent compressor surge?
Scion XB 1NZ-FE Turbo build xbgod Forced Induction Forum 417 07-24-2011 09:16 PM
XBG's Total Build and Update Thread xbgod Performance Modifications 10 11-18-2010 11:19 PM
Whats needed to turbo charge the yaris? Arkhangel Forced Induction Forum 44 03-02-2009 10:08 PM
