Old 12-05-2010, 03:23 PM   #1
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
I found a pretty good deal on the HKS bov and I wanted to try it out. I don't know the quality of the ZAGE bov, and supposedly the HKS bov helps out with performance.
However, unlike most people, I'm not really a fan of the high pitched noise the HKS bov makes.
Old 12-05-2010, 03:42 PM   #2
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
there's no way a BOV can improve performance unless the BOV you're currently using is malfunctioning. but a good deal is a good deal, go for it! what will you have to do to modify to make it work?
Originally Posted by xnamerxx
you nailed it sir.
Old 12-05-2010, 04:09 PM   #3
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
^ We both believe the Zage BOV isn't working correctly and is still allowing compressor surge to happen.
Hey Peter, where did you mount your meth tank?
Focus_Sh1ft is offline   Reply With Quote
Old 12-05-2010, 05:08 PM   #4
Tamago
Tamago's Avatar
Drives: ZZW30
so you don't think the bypass valve is opening fully on throttle-lift?
isn't the whole idea of a recirculating valve to help prevent compressor surge?
you nailed it sir.
Old 12-05-2010, 05:21 PM   #5
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Unplug the line from the bov and hook it up to a boost gauge to make sure you are getting vacuum when you lift off.
rob323 is offline   Reply With Quote
Old 12-05-2010, 05:29 PM   #6
Tamago
Tamago's Avatar
Drives: ZZW30
you should have vacuum at idle, no need to hook up a boost gauge, just unhook it and stick your finger over it while the engine is idling. you should feel if you have vacuum. is the vacuum line hooked up to the correct side of the throttle body?
you nailed it sir.
Old 12-05-2010, 05:31 PM   #7
rob323
If the vacuum line is hooked up to the wrong side of the throttle body, you will still have vacuum at idle though.
Zage Turbo Kit Install - Toyota Yaris Focus_Sh1ft Forced Induction Forum 160 02-06-2022 09:14 PM
Scion XB 1NZ-FE Turbo build xbgod Forced Induction Forum 417 07-24-2011 10:16 PM
XBG's Total Build and Update Thread xbgod Performance Modifications 10 11-19-2010 12:19 AM
Whats needed to turbo charge the yaris? Arkhangel Forced Induction Forum 44 03-02-2009 11:08 PM
