1ZZfe mod info
What throttle bodies are you guys using for this mod? Year/model and part # would be great. Also is there a write-up on the install?
So far the only part# I have found by searching the site is #22030-OD030 I believe off an older model corolla?
'08 3dr HB, Black Sand, AEM, 16x6.6 Mini-Cooper wheels, DynoMax, Cruise, de-TPMS'ed. |
has to be drive-by-wire and not cable throttle.
that one should be ok if you do the chip/servo swap
Trying to find what year throttle body to use in the different threads in here. I think I saw '06-'08 somewhere.
Does anyone know if I can use TB from a 2003 corolla. Engine cover says VVT-i on it.
I'm pretty sure '03 was still cable throttle.
you're looking for 05 and newer corolla. if you google corolla electronic throttle control you will find more results, since "Drive by wire" actually refers to a steering system, as opposed to throttle. Has to be normal Corolla, XRS was cable controlled. I believe it's through 07 that it will work on the 1nz, but not entirely sure on that.
Toyota Moving Forward ...even when you don't want it to. Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
![]() Drives: 2004 Corolla Join Date: Jan 2011
sorry for the late chime.
just wanted to post up 03/04 and 05XRS were drive by cable 05+ are drive by wire I have an 04 Corolla =D |
Will a 2005 Corolla 1ZZ TB work?
found one for $140
![]() ![]() ![]() Drives: Yaris Sedan Supercharged Join Date: Sep 2010
Yup.... I have one on mine.... I luv it.... make sure u adjust the idle screw though, if not it gonna idle all crazy..... lol
#14 |
Right on str8
#15 |
U will like the performance on it.... make sure u also swap the chips on it....
#16 |
Yep I plan to do the chip swap. Got to find that write-up again on all the steps. I think I'm gonna bypass the coolant too.
#17 |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
whats this about a simple TB upgrade?
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#18 |
Yup did the bypass also..... its good...
| PINOUT info stereo | ozmdd | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 12-14-2009 07:52 AM |
| My latest mod and last mod for awile due to stupid economy and hour cuts.... | YarisSedan | Cosmetic Modifications (Exterior/Interior) | 8 | 11-18-2009 05:19 PM |
| $1,600 Government Rebate on Fatt Batt Insulation or Solar Hot Water Systems Info. | *MAD DOG* | Australia | 1 | 03-27-2009 09:44 AM |
| manual transmission: to mod or not to mod? | tomato | General Yaris / Vitz Discussion | 34 | 03-08-2009 10:40 AM |
| swap for 2zz-ge???? | yarisTOONR82 | Performance Modifications | 12 | 03-23-2007 07:15 PM |
