Old 12-07-2010, 04:33 PM   #1
Hard_Yaris
Drives: 07 Yaris
Airbag monitor malfunctioning
Today when i started her up it was about -19C this morning.
the Airbag "ON" and "OFF" light for the first time was set to "OFF" then after it warmed up both on and off where not lit up. and continue to be this way.
The yaris manual basically says "Take it to a Toyota Dealership Imeditaly"
Ill keep an eye on it for the next couple days.
Has anyone had this problem?
Thanks.
Hard_Yaris is offline   Reply With Quote
Old 12-07-2010, 04:55 PM   #2
That's actually a normal behavior. If there was an issue the airbag off light would stay on and the passenger seatbelt light would flash quickly.
You can verify that it is working correctly by sitting in the passenger seat and verifying that the airbag on light comes on.
Old 12-07-2010, 08:35 PM   #3
Hard_Yaris
Drives: 07 Yaris
Good to know! Ill test that tomorrow morning . Thanks CTScott!
Old 12-08-2010, 11:20 AM   #4
Hard_Yaris
Drives: 07 Yaris
Its working fine.
Im very sure the on light has always stayed on.
This is this first time i noticed that it turned to the off position when no one was in the seat.
Very Odd.
Old 12-08-2010, 11:27 AM   #5
Originally Posted by Hard_Yaris View Post
Its working fine.
Very Odd.
Based on my work with the passenger occupancy ECU, I think that the light going out has to do with the zero point calibration. It may be when the 4 occupancy classification sensor readings are less than the zero point that it turns the light off.
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
Help! Airbag light issue Astroman DIY / Maintenance / Service 24 05-18-2019 12:35 PM
Passenger Airbag Question RedStickHam DIY / Maintenance / Service 13 06-23-2013 04:39 PM
passenger airbag light problem (NOT stuck on) ersheff General Yaris / Vitz Discussion 3 10-12-2010 08:20 AM
WTB: Driver Airbag, Airbag Control Module, Upper Tie Bar opdmize Willing to Buy by private party 1 03-19-2010 01:01 AM
