Old 01-20-2011, 01:56 PM   #1
recommended: Redline MT-90 transmission fluid
just had the transmission fluid changed in the yaris (a little late at 70,000km)
tranny feels smoother even though it -10C + windchill today...
i like it.
Old 01-20-2011, 02:12 PM   #2
Hershey
Used that for a 2008 3 door . Does wonders , especially for cold shifting . Took little ove 1 hour to change out the fluid . Well worth the $25 for the 2 quarts .
Old 01-20-2011, 05:42 PM   #3
swidd
Drives: Yaris HB
Hell yeah! It totally fixed sticky gears, and made it way smooth. Cold wx is no challenge.
I changed at around 40,000, and 70,000 ... will change again at 100,000.
GL-4 seems to run better than GL-5 based gear oils... I tried a few different oils the first time I changed it. The Valvoline GL-5 gear oil totally messed it up.
Old 01-20-2011, 05:48 PM   #4
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
Is THIS or THIS of which you speak of?
Old 01-20-2011, 06:22 PM   #5
the first link....the MT-90
Old 01-20-2011, 06:25 PM   #6
Shinare
Shinare's Avatar
2 of those will do?
Old 01-20-2011, 07:06 PM   #7
Hard_Yaris
Drives: 07 Yaris
Redline MT 90 GL-4... Great Stuff! Been running it for a while(40K) and only a few days out of a week long cold snap(~-25C) made the clutch sticky.
Hard_Yaris is offline   Reply With Quote
Old 01-20-2011, 10:13 PM   #8
Lucas13
Drives: 07 Yaris LB
I replaced the whatever stuff the dealer put in the new tranny with Redline Mt 90 and it really makes a big difference, It feels a lot quieter, the reverse doesn't lock any more and all the gears shift a lot smoother.
Lucas13 is offline   Reply With Quote
Old 01-20-2011, 10:16 PM   #9
Originally Posted by Shinare View Post
2 of those will do?
buy 3
i used 2 and bit quarts...
Old 01-20-2011, 11:48 PM   #10
Hershey
Only 2 quarts needed . Make sure car is level as possbile , then pour into filler hole until it runs out and comes to a slow drip .Then replace the plug . Can get a bit messy , but well worth it . When finished take it for a good spin and work through all the gears , including reverse . You'll notice a big difference not long after . The clunk into reverse disappeared as well . May want to take the car for a drive before the gear oil change so it flows out better when warm / hot ( metals suspended in oil ) . Good Luck .
Old 01-21-2011, 01:54 AM   #11
yaris2010RS
yaris2010RS's Avatar
hershey, u love oil threads.....
as for only needing 2 quarts, i would personally buy a little more, if u luck out and dont touch it then u can return it, but if u need it at least its there, better to have too much then not enough. especially if thats the only car u have to get to the store to get more oil if needed.....
Old 01-21-2011, 12:30 PM   #12
Hershey
Use a funnel with clear plastic tubing / hose that goes into the filler hole . Can get them at WAL-MART for reasonable price . I used only 2 quarts with no BP oil spill .
Old 01-21-2011, 01:06 PM   #13
yaris2010RS
ROTFL!!
for all who plan to go out and buy a funnel, dont get a metal flexi one, they leak in all the joints.
Old 01-21-2011, 07:45 PM   #14
Happy Little Pony
Drives: 2007 Yaris HB
Another "me too" for the MT-90. I did actually notice an improvement. Worth it.
Happy Little Pony is offline   Reply With Quote
auto transmission fluid change bribri DIY / Maintenance / Service 4 01-01-2012 11:39 AM
Royal Purple Transmission Fluid caveatipse DIY / Maintenance / Service 14 01-09-2010 04:02 PM
Transmission vent hose leaking fluid Kavi General Yaris / Vitz Discussion 2 06-15-2009 08:14 PM
wrong transmission fluid? supmet DIY / Maintenance / Service 14 02-19-2009 05:01 PM
Transmission Fluid caveatipse DIY / Maintenance / Service 2 09-15-2007 07:03 PM
