Old 06-15-2009, 03:47 AM   #1
Kavi
Transmission vent hose leaking fluid
1. I have recently bought a Yaris 1.0 (yr 2005). Being a novice I asked the mechanic to change the fluid of the automatic transmission. The mechanic overfilled it as the fluid is foamy and leaks out of the transmission hose vent only when engine is cold and idling. Is it bad for my transmission or is there anything I can do by myself?
Kavi is offline   Reply With Quote
Old 06-15-2009, 06:52 AM   #2
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
Yes it is bad for the transmisson. The fluid is being churned by the moving internal parts of the transmisson. The problem with this (besides the obvious mess) is the entrained air is making the fluid a less effective lubricant. This increases wear and heat production. The air bubbles also expose more surface area of the fluid to heat and oxygen which drastically increase the oxidation rate of the fluid, causing it to degrade much more quickly.
You could try to estimate the amount it is overfilled and drain fluid out the trans pan drain plug in small increments to bring the level into the proper range. You could also return it and have the shop correct it since they overfilled it, ASAP.
R2D2 is offline   Reply With Quote
Old 06-15-2009, 07:14 PM   #3
GeneW
Drives: 2008 Yaris
Either Mr. Badwrench over filled it or they put the wrong fluid in. My 2008 takes some sort of "WTS" grade of fluid. Anything is else bad news. I imagine that the same thing goes for earlier models.
I'd have it towed to either the Mechanic or to a professional tranny shop. I would not under any circumstances but an emergency drive it at all.
Gene
Royal Purple Transmission Fluid caveatipse DIY / Maintenance / Service 14 01-09-2010 03:02 PM
Transmission Questions(fluid change... and other questions) Lafiro DIY / Maintenance / Service 6 04-01-2009 07:52 AM
wrong transmission fluid? supmet DIY / Maintenance / Service 14 02-19-2009 04:01 PM
Transmission Fluid caveatipse DIY / Maintenance / Service 2 09-15-2007 06:03 PM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
