recommended: Redline MT-90 transmission fluid
just had the transmission fluid changed in the yaris (a little late at 70,000km)
tranny feels smoother even though it -10C + windchill today... i like it.
Used that for a 2008 3 door . Does wonders , especially for cold shifting . Took little ove 1 hour to change out the fluid . Well worth the $25 for the 2 quarts .
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
Hell yeah! It totally fixed sticky gears, and made it way smooth. Cold wx is no challenge.
I changed at around 40,000, and 70,000 ... will change again at 100,000. GL-4 seems to run better than GL-5 based gear oils... I tried a few different oils the first time I changed it. The Valvoline GL-5 gear oil totally messed it up. |
Bronze bombshell yaris
Drives: 09 Yaris HB 3door Join Date: Sep 2010
Now I drive a CARMINE RED METALLIC 09 Yaris 3-door!! I'm Back!!! WooHoo!! Mods done so far: Tinted windows, Viper 211HV Remote Keyless Entry, Atoto Android headunit, backup camera, steering wheel controls Before it was totaled I drove a 2007 Black Sand Pearl 3 Door Lift-Back M/T with 49k miles. Stock Everything except for black tint, all red badges, red dash, and stealth garage door opener. Ultra-Gauge mounted on steering wheel. A1 Electric MES Central Locks and Avital 3100 Alarm system.
the first link....the MT-90
2 of those will do?
![]() ![]() Drives: 07 Yaris Join Date: Dec 2009
Redline MT 90 GL-4... Great Stuff! Been running it for a while(40K) and only a few days out of a week long cold snap(~-25C) made the clutch sticky.
![]() ![]() ![]() Drives: 07 Yaris LB Join Date: Aug 2007
I replaced the whatever stuff the dealer put in the new tranny with Redline Mt 90 and it really makes a big difference, It feels a lot quieter, the reverse doesn't lock any more and all the gears shift a lot smoother.
Only 2 quarts needed . Make sure car is level as possbile , then pour into filler hole until it runs out and comes to a slow drip .Then replace the plug . Can get a bit messy , but well worth it . When finished take it for a good spin and work through all the gears , including reverse . You'll notice a big difference not long after . The clunk into reverse disappeared as well . May want to take the car for a drive before the gear oil change so it flows out better when warm / hot ( metals suspended in oil ) . Good Luck .
#11 | |
as for only needing 2 quarts, i would personally buy a little more, if u luck out and dont touch it then u can return it, but if u need it at least its there, better to have too much then not enough. especially if thats the only car u have to get to the store to get more oil if needed.....
Use a funnel with clear plastic tubing / hose that goes into the filler hole . Can get them at WAL-MART for reasonable price . I used only 2 quarts with no BP oil spill .
ROTFL!!
for all who plan to go out and buy a funnel, dont get a metal flexi one, they leak in all the joints.
![]() ![]() Drives: 2007 Yaris HB Join Date: Dec 2009
Another "me too" for the MT-90. I did actually notice an improvement. Worth it.
| auto transmission fluid change | bribri | DIY / Maintenance / Service | 4 | 01-01-2012 10:39 AM |
| Royal Purple Transmission Fluid | caveatipse | DIY / Maintenance / Service | 14 | 01-09-2010 03:02 PM |
| Transmission vent hose leaking fluid | Kavi | General Yaris / Vitz Discussion | 2 | 06-15-2009 07:14 PM |
| wrong transmission fluid? | supmet | DIY / Maintenance / Service | 14 | 02-19-2009 04:01 PM |
| Transmission Fluid | caveatipse | DIY / Maintenance / Service | 2 | 09-15-2007 06:03 PM |
